Code 601 - PCM repacement????? Could it be?
Old 12-30-2005, 12:02 PM
beech2000's Avatar
beech2000
beech2000 is offline
Default Code 601 - PCM repacement????? Could it be?
Keep pulling code 601 from my sisters 2001 Dodge Caravan Sport. All OBDII List keep telling me is that a computer controller failure. Does this mean the computer has failed???. If so, how many hundreds of dollars could this cost her / me?
Spent 2 hours now searching the web for info on code 601's and it seems as if very few have experienced this. I am afraid to clear code as I wonder if my problem is not more related to drive time/cycle as apposed to actual computer errorr.
Please help as I sure find it hard to believe thier are no other options.
Old 12-30-2005, 01:44 PM
aldovera's Avatar
aldovera
aldovera is offline
Default RE: Code 601 - PCM repacement????? Could it be?
A new PCM will cost you between 3 to 5 hundred dollars.
And what's the van doing? Is it running?
Old 12-30-2005, 02:15 PM
beech2000's Avatar
beech2000
Its running fine. Check engine light stays on
Old 01-01-2006, 12:55 AM
tenntech's Avatar
tenntech
tenntech is offline
A p0601 is a internal failure in the pcm. The code will not clear and the only fix is to replace the pcm.
Old 01-01-2006, 04:11 PM
brandoncrone's Avatar
brandoncrone
brandoncrone is offline
Its probably still under warranty, covered under the 8 years, 80000 mile federal emission warranty
Quick Reply: Code 601 - PCM repacement????? Could it be?
