Charging System Diagram
Old 12-19-2005, 02:21 AM
Dodge4Life's Avatar
Dodge4Life
Dodge4Life is offline
Default Charging System Diagram
I am having a problem with my charging system, the alternator works, but it is not charging the battery, i was wondering if anyone had a wiring diagram for the charging system on a 1982 dodge ram with a small block v-8. Thanks for the help.
Old 12-19-2005, 03:44 AM
horatio102's Avatar
horatio102
horatio102 is offline
Default RE: Charging System Diagram
How do you know the alt is good? Did you pull it off and test it? If you did, and it tested good, I'd buy a new voltage regulator and swap it out. They're known to go bad every now and again. It's the rectangular box bolted to the firewall right behind the engine, 2 bolts and an odd-shaped wire connector. Not as many shops can test those as alternators, but it doesn't hurt to ask. They should run about $30 or so I think, maybe less.
Old 12-19-2005, 02:57 PM
Dodge4Life's Avatar
Dodge4Life
I know its not the alt, but it could be the voltage regulator or the wiring, i am not sure, and the diagram in my book sucks. I really just need a better diagram. I am going to check out the regulator and see what happens with that. They are pretty cheap any way.
Old 12-20-2005, 03:30 AM
Chump's Avatar
Chump
Chump is offline
The voltage regulater gets it's ground through the metal case and the firewall. Should be able to pickup a new VR at Autozone for around $12.
Old 12-20-2005, 01:07 PM
DodgeRam318_4bbl's Avatar
DodgeRam318_4bbl
DodgeRam318_4bbl is offline
I know that Advance Auto Parts and AutoZone can test the alternator and the voltage regulator.
Old 12-20-2005, 05:02 PM
Dodge4Life's Avatar
Dodge4Life
Not the ones here, i already took the vr in there and neither of them had the tester... Our advance is like 4 months old and the auto zone is just over a year... Stupid little town... I am just going to go buy a new vr today, i hope that does it.
Old 08-22-2010, 07:40 PM
nephelim's Avatar
nephelim
nephelim is offline
Shouldn't the amp meter show discharge if the alternator and or the voltage regulator are bad. My amp meter does not move when I turn on the key or turn on the lights. Or when I start the vehicle it just stays in the same spot. So what can be the trouble? O have a 1984 Dodge Ram one ton van.
Old 04-20-2011, 08:25 AM
mesaazmuffman's Avatar
mesaazmuffman
mesaazmuffman is offline
Default wiring diagram
im building a dodge dart dirt track car and need a simple wiring diagram for the charging system
Old 04-20-2011, 08:33 AM
crazzywolfie's Avatar
crazzywolfie
crazzywolfie is offline
if you want simple buy an alternator with a built in regulator.
Old 04-20-2011, 12:11 PM
mesaazmuffman
Default simple
then what alt would i run on a small block and where would the wires run i need to see it on paper
Quick Reply: Charging System Diagram
