04 r/t stratus upgrades
Old 04-20-2004, 02:57 AM
/RTguy's Avatar
/RTguy
/RTguy is offline
Default 04 r/t stratus upgrades
I just got a 2004 stratus r/t coupe. i am looking for some preformance parts. cold air. chip. maby a turbo, exasust anyone have any idea of a good site to find these items? 3.0 btw
Old 04-20-2004, 10:51 PM
BadStratRT's Avatar
BadStratRT
BadStratRT is offline
The Forum Tyrant
Default RE: 04 r/t stratus upgrades
well, if you act fast, there are headers for it on ebay.
I have a 02 RT coupe, and i am currently waiting on a CAI in the mail. I have custom mufflerless tuned catback, and a 175 degree thermostat.
The chip is tricky because unlike alot of cars, there is no "chip". You either have to buy a programmable ECU, or send out your current ECU to have it reprogrammed. The turbo is a bit harder to find, but they are out there, and im ont sure who makes them. Check out Ripp Mods, the owner has a heavily modded 02 RT, and that company specializes in building superchargers, and the owners RT has said supercharger.
Old 05-01-2004, 03:59 AM
iceman33's Avatar
iceman33
iceman33 is offline
Yeah, go to GeneralMotors.com and buy yourself a 350 V8 chevrolet engine and install it in your Stratus. Move to a Alaska, where its cold to take care of your cold-air intake, and this should get you the turbo horse-power you are looking for. You won't need a "chip" with this engine, it'll do fine on its own. Install the dodge engine on your lawn mower, it'll probably handle that o.k.
Old 05-02-2004, 06:05 PM
BadStratRT's Avatar
BadStratRT
The Forum Tyrant
...or you could buy a good engine from mopar performance and put it in a different car, rather than having to sit and read stupid replies from morons, when youre trying to get help with your car.
Old 05-06-2004, 06:11 PM
moparturd's Avatar
moparturd
moparturd is offline
After your GM pile of poopy blows up, take the mopar engine off the your lawnmower, install it where the GM poopy was, and haul what's left to the junkyard with all the other GM poopy.
Sorry dodgemech, no offense man.
Old 05-06-2004, 06:24 PM
npeifer's Avatar
npeifer
npeifer is offline
I actually have a set of headers that will be available in a week or so. Also guys there are many upgrade parts available for those looking for things for a strat. I have a stage 2 Supercharged Stratus R/T running 17 PSI of boost and making about 400hp at the front wheels. Here is a list of my current mods:
2001 Dodge Stratus R/T 5 Speed
Gallipolis, Ohio
RIPP Mods Stage 2 setup
V1 S-Trim blower
RIPP Black Box
Methanol Injection kit
9:1 CP Forged Pistons .040 overbore
Cryo treated and balanced stock rods
ARP Rod Bolts
Clevite Bearings
High Compression Head Gaskets
Fully Balanced rotating Assembly
Full custom Race Port and Polish
Ferrea stainless 1mm over valves
Titanium retainers
Custom Double Valve Springs
Lunati Camshafts for SC application
GTS Upper Plenum
Pro Flow 62mm Throttle Body
Venom 310cc injectors
Walbro 255 pump
Energy Suspension front and rear Motor mounts
DM Racing side mounts
Kaaz LSD
cryo treated gearset in transmission
Spec stage 3 4 puck clutch
Spec aluminum lightened flywheel
B & M short shifter
AMSS Headers Gen 2
I'm sure there is more but its hard to remember everything ?
Now runing and working out the bugs !! I will Dyno when ready.
If I can be of any assistance please let me know.
Old 05-06-2004, 06:48 PM
moparturd's Avatar
moparturd
HOLY CRAP. Now there is something we need a link to.
Old 05-06-2004, 07:01 PM
npeifer's Avatar
npeifer
npeifer is offline
I hang out mostly on these 2 web sites but here is the link to a sponsor of mine (RIPP modifications) www.rippmods.com
The sites are:
www.2gstratus.org
and
www.neweclipse.org
I will be at the mopar nationals this year in Columbus, Ohio Aug 13-15, and at Norwalk for racing Aug 13-15th for the Sport compact nationals. I expect to run in the 11's with the current setup and it is perfectly driveable on a daily basis.
Old 05-07-2004, 02:02 AM
BadStratRT's Avatar
BadStratRT
The Forum Tyrant
hey peifer, im rt02racer from 2g! i didnt realize you had that much stuff done!
Old 05-07-2004, 11:46 AM
npeifer's Avatar
npeifer
npeifer is offline
I just found this place but it doesn't seem to be as active as 2Gstratus or neweclipse.org. The members here should check them out.
Quick Reply: 04 r/t stratus upgrades
