torsion/shackle lift
Old 11-13-2005, 03:10 PM
t.lay's Avatar
t.lay
t.lay is offline
Default torsion/shackle lift
Does anyone have a write up on the "how to" of doing the torsion/shackle lift? I've seen it in the forum, but haven't been able to reach it with the search function
Old 11-18-2005, 08:05 PM
mtndewnut's Avatar
mtndewnut
mtndewnut is offline
Default RE: torsion/shackle lift
Very very simple to do.
1. Jack up the rear of the vehicle and support the FRAME with jackstands.
2. Lower the jack and pull it out. (Wheels should not touch the ground)
3. Remove the REAR shackle bolts (If you have a hitch, that will have to be removed first.)
4. Then the spring will actually go up. (You would think that it would drop down, but it doesn't)
5. Remove the stock rear spring shackle
6. Replace with the new shackle (It's actually a lowering shackle for a Chevy pick-up)
7. You will need a bottle jack for this step. Place a bottle jack in between the frame and the leaf spring and raise it untill it comes down low enough to replace the rear spring shackle bolt. You will need to buy some washers for spacers because the shackles are slightly wider than the spring.
8. Do the same thing to the other side and you're done! (with the rear)
9. Lower the rear and raise the front of the vehicle
10. With a large breaker bar tighten the torsion bar adjustment 8 equal turns. (mark your starting point) This will raise the front of the vehicle to match the rear.
11. Do that to both sides and lower the front.
12. Measure from the ground to he bottom of the fender (at the wheel) Make sure that distances are equal.
That's It!
Old 11-19-2005, 02:23 AM
stlbird3223's Avatar
stlbird3223
stlbird3223 is offline
how much does a torsion shackle lift cost?
Old 11-19-2005, 02:57 AM
mtndewnut's Avatar
mtndewnut
About $50.00 for the rear spring shackles. For the front it costs nothing because all you are doing it cranking the torsion bars.
Old 11-19-2005, 06:53 PM
stlbird3223
ive looked everywhere online and cant find the shackles. where did you get them?
Old 01-08-2008, 03:08 PM
Rocksurfer's Avatar
Rocksurfer
Rocksurfer is offline
The link above is bad, I am currently doing this lift and it is coming along fine, here's my before pics and I just finished cranking in the front, just got my lowering/lift shackles from 4 wheel Parts. I ordered the 2" lowering shackle for an 89 Chevy C1500. I couldn't stand the gold color so I painted them black.
[IMG]local://upfiles/63521/12FA13D06EE843F7B6B5490D998A1810.jpg[/IMG]
[IMG]local://upfiles/63521/5E67C7F1D3B74F6884206B82923C6530.jpg[/IMG]
[IMG]local://upfiles/63521/8810261FE81041EB95A060BBD0A8073E.jpg[/IMG]
[IMG]local://upfiles/63521/6B73E6F98AA9444AB0FC198DCA2ADC55.jpg[/IMG]
Old 01-08-2008, 03:19 PM
Rocksurfer's Avatar
Rocksurfer
Frontend before and after, I got just about 2" total out of the front. Wife's gotta have the truck again today so I climbed under it and made sure the bolts aren't rusted in, I'm going to put them on when she gets home, should post more pics tommorrow after I lift the rear.
[IMG]local://upfiles/63521/754FE32F91B74BFFAC5F3C1F358493F0.jpg[/IMG]
[IMG]local://upfiles/63521/419D0C3E66A44B138988BAF70E44067F.jpg[/IMG]
[IMG]local://upfiles/63521/2837C6BB3A07487B850744300D266E1E.jpg[/IMG]
[IMG]local://upfiles/63521/411C0419B57944349357DBD253D8C7BA.jpg[/IMG]
Old 01-08-2008, 03:31 PM
deerang's Avatar
deerang
deerang is offline
that link is over 2 years old...
you just put in the cheapest levelling kit ever... How's the wifey liking the extra few inches to climb in??
Old 01-08-2008, 08:33 PM
Duranged408's Avatar
Duranged408
Duranged408 is offline
I cant remember what size washers i used, but it ended up being 4 per side.
Old 01-09-2008, 10:41 PM
Rocksurfer's Avatar
Rocksurfer
Done with the shackles took 4 flat washers per side like mentioned, I split the difference with 2 on each side of the shackle to center it. The springs required no washers at all, was pretty straight forward. I used my sissors jack to spread the spring away from the frame to be able to align the holes. My wife has always enjoyed the higher profile vehicles so she'll be happy with it. The on e thing I did do was to make sure that the bolts were not rusted on, I loosened each bolt and tapped it out just a little to see if they were stuck. Fortunatly they all came out very easily.
[IMG]local://upfiles/63521/8BDC279024B54B34939B7B2E40B647D4.jpg[/IMG]
[IMG]local://upfiles/63521/94223F5B401A430CA52DCD9A79FFE0A7.jpg[/IMG]
[IMG]local://upfiles/63521/9A1B724E2A0846BB886C56D7981646D2.jpg[/IMG]
Quick Reply: torsion/shackle lift
