what about thermoplastic bushings ?
Old 07-15-2014, 07:43 PM
LIZZRD's Avatar
LIZZRD
LIZZRD is offline
Default what about thermoplastic bushings ?
So i got my Moog, fairly hard Blue sway bar bushings, in the mail the other day. After a couple days of wire brushing and some penetrating oil i replaced some sorry looking, skinny sway bar links. So glad the Moog came with new bolt/nut.
The rear left shock is in the way for access to the top bolt but can be had with 15 + 19mm deep well socket and wrench. Right side top , i got a little room after
un-hanging the tail pipe and going to my 3/8 drive after doing most work with 1/2" drive socket. At the same time i also sprayed and backed out the bolts holding the sway bar bushings to the axel mounts, (right other side of shock). All these bolts are getting cranked out after about 18years, most spent in the mid-west (salt). The new thermoplastic material is stout stuff, i really don't see the bushings which are split to open enough to go right on. I guess i could undo the links and slide them on with probably some lube, but from my searching there is no lube for these hard bushings. Are the bushings supposed to spread/open onto the bar ?
I wonder about maybe some hot water to aid in the opening ?
Someone with first hand help me/us !
Old 07-15-2014, 08:29 PM
LIZZRD's Avatar
LIZZRD
LIZZRD is offline
yea, i can see some resent activity going on under there, some much needed brake work and booster. So, i was drawing thinking about this and decided to take a pic... you would being doing ok to pull that dime out...
Old 07-19-2014, 10:21 AM
jondakotaguy's Avatar
jondakotaguy
jondakotaguy is offline
is this something aftermarket bc i dont think my 97' SLT 4x4 has this.
Old 07-19-2014, 10:44 AM
RalphP's Avatar
RalphP
RalphP is offline
Those are aftermarket bushings for an optional (rear) or original (front) sway bar.
Me? I ordered first the Raybestos "OEM fit" for my 1988, but they were for a smaller swaybar, so I then measured the bar and ordered some poly ones from Energy Suspension that are greaseable (to help keep the "OOkookOOKook" down)
They actually spread EASIER than the rubber ones did, go figure.
Still, they're not exactly "Jump on up in here!" easy.
Good news is, with my bar out, I can slip them on a lot easier.
RwP
Old 07-19-2014, 11:23 AM
98DAKAZ's Avatar
98DAKAZ
98DAKAZ is offline
"OOkookOOKook"
That's funny
I would like the poly bushings if they were actually formed in the metal bushing sleeve like OEM rubber ones. That’s the reason poly bushings make that ugly noise they move in the bushing sleeve OEM rubber ones are molded into the metal sleeve so no movement or sliding in the sleeve. Now steering stabilizers are not molded but the OEM rubber doesn’t make any noise were as poly will make that strange noise.
OOkookOOKook
Old 07-19-2014, 12:41 PM
jpayne80's Avatar
jpayne80
jpayne80 is offline
My bushings for my front sway bar bushings were the same way. I think it is normal.
BTW, love the elephant!
Old 07-21-2014, 11:34 AM
LIZZRD's Avatar
LIZZRD
LIZZRD is offline
yea, they are aftermarket ... MOOG.
obviously i will have to unbolt the end links(they are not torqued yet)
and clean/grease bar to slide on. I had the bushing clamps loosened a few threads and after picking up some lumber Sat. the clamps/bushings become un-stuck...
Old 07-21-2014, 01:48 PM
RalphP's Avatar
RalphP
RalphP is offline
Originally Posted by 98DAKAZ
That's funny
OOkookOOKook
Yah, back in the 70's I learned that as "The Mating Call Of The Small Ford Front End" *grins* Most all early Mustangs, Falcons, and Mavericks used to make that same sound.
That reminds me - the poly ones on the Cougar need a shot of lube again.
AND - the Dakota is going to hit the ground again tonight, alignment tomorrow morning (or so's the plans anyway.)
The sway bar bushings aren't molded into the sway bar brackets from the factory either - the rubber just gives a bit more.
As to the bushings - the rubber is quieter because typically the rubber yields, whereas the center shaft rubs on the poly bushing (which doesn't yield). If they bound it tight, the bushing might as well be aluminum solid for all the give it'd have.
RwP
Quick Reply: what about thermoplastic bushings ?
