2004 SE cranks no start no codes
Old 07-15-2014, 08:56 AM
wtester's Avatar
wtester
wtester is offline
Default 2004 SE cranks no start no codes
2004 neon 2.0 automatic, no start no codes if you crank and crank it will occaisionlly start then once warm its fine. Since no codes are being thrown, replaced cam sensor it has, good plugs wires and new coil also. Acts like crank sensor but again no codes being thrown
Old 07-15-2014, 09:53 AM
TejasMtnBiker's Avatar
TejasMtnBiker
TejasMtnBiker is offline
all fuse's good? When you turn the keys to on, do you hear the fuel pump run or "prime"
Old 07-15-2014, 03:15 PM
wtester's Avatar
wtester
wtester is offline
yeah pump kicks right in actually got it to start had to pump accelerator several times
Old 07-15-2014, 08:17 PM
wtester's Avatar
wtester
wtester is offline
replaced crank and cam sensor car will start but you have to pump accelerator once it starts and smooths out runs great and will restart in an instant but if it sits goes bac to lots of cranking
Old 07-16-2014, 06:47 AM
wtester's Avatar
wtester
wtester is offline
Still no codes being thrown, I unplugged a sensor to test it and it logged it in instantly, key dance revealed it was correct given what I did to trip it. So I am fairly comfortable that the OBDII is working as it should. Could an IAC be the culprit since you have to flog the throttle to assist the start?
Old 07-25-2014, 06:07 AM
wtester's Avatar
wtester
wtester is offline
Replaced plugs starts better now runs great then got a PO300 yesterday random misfire went ahead and replaced wires, replaced coil about 6 months ago. this car will make you crazy
Quick Reply: 2004 SE cranks no start no codes
