brake pressure problem on 04 dak
Old 07-15-2014, 07:32 AM
sneeky1's Avatar
sneeky1
sneeky1 is offline
Default brake pressure problem on 04 dak
So if I press the pedal hard the pedal is firm as it should be. If I slowly press it it will go all the way to the floor. Problem started last week and progressively got worse. Any help would be great.
Old 07-15-2014, 08:43 AM
that_guy's Avatar
that_guy
that_guy is offline
Sounds like the cups in the master cylinder aren't sealing well anymore if you ask me. When you hit the pedal hard the fluid doesn't have time to leak around them yet, so the pedal is firm, but if you push it slowly it is letting the fluid leak around the cups.
Old 07-15-2014, 10:25 AM
98DAKAZ's Avatar
98DAKAZ
98DAKAZ is offline
Are you loosing any fluid/DOT 3?
Drums on the back?
Old 07-15-2014, 11:16 AM
sneeky1's Avatar
sneeky1
sneeky1 is offline
Haven't lost fluid. Still full and I didn't see any leaks
Old 07-15-2014, 11:18 AM
sneeky1's Avatar
sneeky1
sneeky1 is offline
I'll double check when I get home
Old 07-15-2014, 04:15 PM
sneeky1's Avatar
sneeky1
sneeky1 is offline
double checked and no fluid leaking.
Old 07-15-2014, 06:00 PM
dolittle's Avatar
dolittle
dolittle is offline
I with Guy on this. Sounds like a bad master cylinder.
Old 07-16-2014, 05:15 PM
sneeky1's Avatar
sneeky1
sneeky1 is offline
it was the master cylinder. Thanks for the help everyone.
Quick Reply: brake pressure problem on 04 dak
