2004 Neon wipers won't stop running
Old 07-14-2014, 10:11 PM
Mike E's Avatar
Mike E
Mike E is offline
Default 2004 Neon wipers won't stop running
Hey, I just bought a 2004 Neon with a problem.
When the car is not running I can turn the ignition switch to "on" and the wipers work normally, on, off, delay...
If I start the engine, wipers run all the time and will not turn off.
Get this...
If I step on the brake the wipers stop. If I let go the brake the wipers start going again.
Does anyone have any idea what could be causing this?
I have tryed 2 other multifunction switches and same thing. I have switched the wiper motor, same thing.
Is there a relay in this circuit? If so, where is it?
Thanks much, Mike
Old 08-30-2015, 06:46 PM
winr's Avatar
winr
winr is offline
Default what happened?
Mike what was the resolution of the wiper issue???
Old 09-01-2015, 10:17 PM
winr's Avatar
winr
winr is offline
Default my solution
Ok since Mike dosnt seem to be on here much and I needed to get my Daughters car finished I had to diagnose the answer myself (no shortcuts)
The answer is... a bad (shorted)washer pump motor and multi function switch(stuck on wash).
I got ahold of a wiring diag and started pining things out and found power going to the washer pump (at the switch) but the pump was not running, so I unplugged the pump and voila...issue gone. The stalk wasn't in the wash position so it must be stuck/shorted.
Old 09-02-2015, 09:08 AM
Mike E's Avatar
Mike E
Mike E is offline
Sorry for the delay, computer issues...
That was the solution for me too. I unplugged the windshield washer pump and everything worked fine after that. I just left it unplugged.
Quick Reply: 2004 Neon wipers won't stop running
