Does my 99 ram 1500 5.2 have an EGR valve?
Old 07-14-2014, 04:03 PM
bignasdy's Avatar
bignasdy
bignasdy is offline
Unhappy Does my 99 ram 1500 5.2 have an EGR valve?
Please pardon my ignorance, I'm having a brain fart here....Im ordering the mopar m1 intake since I have the plenum problem, and I don't know if I have an EGR valve or not....there are two versions for fuel injection intakes, EGR connection or without. I bought the truck in texas if that matters.
thanks in advance,
d
Old 07-14-2014, 04:14 PM
snowboundrmk's Avatar
snowboundrmk
snowboundrmk is offline
You don't have egr.
Old 07-14-2014, 08:47 PM
bignasdy's Avatar
bignasdy
bignasdy is offline
the dude at jegs said I do...I ordered the mopar mpi intake with the egr...the dealer said it came with egr....they wrong? I asked a bunch of people ...they said egr. Hope your wrong...
I done paid for it
Old 07-14-2014, 09:14 PM
ReadRam's Avatar
ReadRam
ReadRam is offline
No egr on a 99, sorry. Change your order or maybe you can plug it, if it's just a port.
Old 07-14-2014, 09:26 PM
AtomicDog's Avatar
AtomicDog
AtomicDog is offline
Either M1 intake will work, EGR or not. I just purchased a used M1 intake with EGR provisions and I'm just going to block the EGR provisions off, since my 5.9 motor does not have EGR provisions.
Old 07-14-2014, 11:08 PM
bignasdy's Avatar
bignasdy
bignasdy is offline
I said m1 but its the mopar performance MPI. My mechanic just stopped by and he says no egr thanks guys, I got the order switched as soon as I confirmed what yall said. Thanks again!
d
Old 07-16-2014, 01:43 PM
bignasdy's Avatar
bignasdy
bignasdy is offline
heres what I got comin...
http://www.jegs.com/i/Mopar+Performa...07852/10002/-1
well..... that's what I had comin ha! Its discontinued and unavailable. There are only 14 left supposedly, of the egr model. Im gonna get that one instead...heres the link...
http://www.jegs.com/i/Mopar-Performa...398AB/10002/-1
Im also considering this....any info appreciated
http://www.ebay.com/itm/BLUE-1994-20...5d2c2b&vxp=mtr
thanks!
d
Old 09-04-2014, 04:03 PM
bignasdy's Avatar
bignasdy
bignasdy is offline
got the mpi manifold in, truck never ran better! Thanks for all the info!
Attached Thumbnails Does my 99 ram 1500 5.2 have an EGR valve?-20140809_100951.jpg
Old 09-04-2014, 04:22 PM
Notice any loss of low end?
Old 09-05-2014, 10:54 AM
bignasdy's Avatar
bignasdy
bignasdy is offline
Absolutely not. It has more torque now than it has in awhile. It had the old plenum gasket fail leak. Also found the check valve in the vacuum line started to cause the ac to default to defrost. $2.75 for a valve from orileys, and its fixed.
Milage is right around 275000. I haul pool tables all over the country in this truck. I definatly pull better and get on the highways way better now, than I could before.
According to Mopar, theres only 13 of these left in stock...ha.
While I was at it, I had to drill out the front two manifold bolts, and I was gonna do a oil pan gasket anyway, so I went ahead and replaced the oil pump. Pan came right out, didn't have to remove anything other than the two trans brackets.
This forum is so helpful.
d
Quick Reply: Does my 99 ram 1500 5.2 have an EGR valve?
