Dakota Converter and other stuff
Old 07-13-2014, 11:51 PM
dakotamod21's Avatar
dakotamod21
dakotamod21 is offline
Default Dakota Converter and other stuff
Hey fellow Dakota lovers,
I am currently in the process of replacing the converter in my truck. The question I have would it be better to buy a flywheel and converter or just an OEM replacement?
And anyone have an idea on how much it would be to have a cab mount straightened out?
Old 07-14-2014, 12:12 AM
RDuck's Avatar
RDuck
RDuck is offline
Your question really doesn't work on either case.
Why are you buying a new converter?
Whats wrong with your flex plate that makes you want a new one?
Are you asking about a high stall converter over a OEM stall?
Can't answer cost on cab mount without seeing the damage and what needs replacement.
Way to generic of questions.
Old 07-14-2014, 12:19 AM
dakotamod21
And these trucks don't have a flex plate stock... it has a flang that blots to the cranks that blots to the converter...Two of the bolts were broke off in it and it acts like it has a high stall in it when you take off after start up but not when you let it warm up and I bent a cab mount on the frame when I was going through a trail and just wanna know if it could be straightened or replaces so the cab isnt saggin to one side
Old 07-14-2014, 12:32 AM
RDuck's Avatar
RDuck
RDuck is offline
Ok. So your flex plate is pooched. Sorry, flange. And your converter is pooched. So you want to know what?
New oem or aftermarket oem?
Im a welder/Fabricator. Company charges $100/hr. Cab mount sight unseen and no information. Two days labour plus parts. Lets say $2500.
A bit high maybe but it answers your question.
Old 07-14-2014, 01:20 AM
magnethead's Avatar
magnethead
magnethead is offline
IF you are handy with a torch and welder, just make sure you unplug the CTM and PCM before welding on the frame.
And I spy in my crystal ball that you are going to have a ton of clutch or band material in your trans pan next time it comes off….the stock convertor doesn't just change properties like that.
Old 07-14-2014, 10:20 AM
dakotamod21
I just was wondering if anyone has put a aftermarket converter in their dakota.
Thats not really what I want to here but it is what it is I guess... could nobby mud tires cause enough vibration in the drive line to work them loose or is that just my guts saying the trans is fine.... lol and thats what I wanted to know about the mount, thanks!
Old 07-16-2014, 09:13 PM
magnethead's Avatar
magnethead
what I meant is that convertors are welded inside, the blade angles can't change. The only way a convertor itself can slip is if it tried to go into lockup, and the lockup clutch comes apart. BTDT. Wiped out whole trans from filling it with clutch dust.
The internal bands and clutches in the trans are what typically slip, either from reduced line pressure (line pressure keeps the clutches pressed together) due to a failing pump, or due to an eroded or otherwise loose band. Either way introduces loose material into the trans which can clog the solenoids and check ***** in the valvebody, leading to terminal failure.
In my case, I had a cracked drum, wasted O/D clutch, 2 clogged solenoids, a worn out clutch pack, and a band at half-life. I had to have it towed because I lost O/D, then drive, then second, then first and reverse. Yea, that wasn't a pretty tow+repair bill.
Quick Reply: Dakota Converter and other stuff
