95' a670 3-speed has drive in all gears.
Old 07-13-2014, 10:49 PM
Plymouthjunk's Avatar
Plymouthjunk
Plymouthjunk is offline
Default 95' a670 3-speed has drive in all gears.
My 95' A670 3-speed transmission has drive in all gears including park, reverse and neutral. I just put a full rebuild kit (minus valve body) in it and I am pretty sure I adjusted everything to the specs necessary. There was a decent amount of metal in the pan when I took it apart. It was from the clutches being completely gone and rings rubbing together. Not sure what's going on.
Old 07-14-2014, 11:36 AM
Something is bunged up in the shift linkage, either externally, or internally..... if everything on the outside looks good, time to drop the pan, and have a look.
Welcome to DF!
Old 07-15-2014, 06:40 AM
Plymouthjunk
Welcome to DF!
Thanks!
Took off the pan last night linkage looks good. I'm think perhaps the forward gear cluster piston is not working properly possible stuck??
Old 07-15-2014, 12:24 PM
Probably wouldn't hurt to post up in the forum appropriate for what it is you are driving. Someone there may have more of a clue for your specific trans.
I would wonder if something in the trans wasn't binding......
Quick Reply: 95' a670 3-speed has drive in all gears.
