Remove front rotor 1996 Ram 1500
Old 07-13-2014, 06:04 PM
diverjer's Avatar
diverjer
diverjer is offline
Default Remove front rotor 1996 Ram 1500
Shouldn't the rotor come off by just removing the calipers and bracket that holds the calipers? I was lead to believe I had to remove the cotter pin and that big wheel bearing/rotor nut. If I wanted to pack the wheel bearings I can see removing that big nut and pin, but i don't think I have to for just the rotor?
Old 07-13-2014, 06:40 PM
4x4 right? Rotor is probably just rusted to the hub. Hit it with a hammer a couple times.
Old 07-13-2014, 06:46 PM
Ham Bone's Avatar
Ham Bone
Ham Bone is offline
i thought the early rotors were behind the bearing
Old 07-13-2014, 07:42 PM
xjarhead69's Avatar
xjarhead69
xjarhead69 is offline
2wd is 1 piece rotor and hub, 4wd rotor and hub are seprate.
Dave
Old 07-13-2014, 07:57 PM
diverjer's Avatar
diverjer
diverjer is offline
Yes, this is a 4X4.
Old 07-13-2014, 09:36 PM
armynurse's Avatar
armynurse
armynurse is offline
It should come right off. If you get two big hammers and hit it at the 3'oclock and 9'oclock positions at the same time, turn the rotor a bit then do it again, it should come loose after just a few hits.
Old 07-13-2014, 10:36 PM
3/4 ton rotors are staked on from the back.
Old 07-13-2014, 10:51 PM
Ham Bone's Avatar
Ham Bone
Ham Bone is offline
Except mine
Old 07-14-2014, 11:47 AM
Originally Posted by Ham Bone
Except mine
Bite me.
I think along about 99 or 00, they got smarter on that....
Quick Reply: Remove front rotor 1996 Ram 1500
