3rd Gen Durango 2011+ models
how to check oil percentage
Old 07-13-2014, 05:32 PM
bjballar41's Avatar
bjballar41
bjballar41 is offline
Default how to check oil percentage
Is there a way to check in the info center to check the oil percentage? we have been about 6000 or so miles and i check from under the hood and it looks fine so i was just curious what the computer would say was left on percentage. we bought the durango used and it still hasnt come up with a msg about changing oil
Old 07-13-2014, 05:57 PM
bjballar41's Avatar
bjballar41
also this is on a 2011 citadel also if i go ahead and change the oil will the computer recognize it or will i need to reset it some how?
Old 07-13-2014, 11:22 PM
JRRF's Avatar
JRRF
JRRF is offline
Not sure about any %, but when the car needs an oil change it will let you know with a little message. You can then reset that (or the dealer will if they change the oil), and then the car will remind you again the next time. It uses an algorithm to determine when the oil needs changing.
Old 07-13-2014, 11:32 PM
shelbymopar89's Avatar
shelbymopar89
shelbymopar89 is offline
The newer ones (13's?) show the %. The older EVIC style just tell you when it needs changed. If you change it early, or when do you have to reset it by doing the following.
1. Without pressing brake pedal, push start button and cycle it to the ON/RUN position, do not start the vehicle.
2. Fully depress the gas pedal slowly three times within 10 seconds.
3. Without pressing the brake pedal, press the start button one more time to cycle it off.
There is a Drive Dodge app and a Durango app that are pretty good. I can not find the Durango app anymore on the playstore, but it shows up in my history and I have been able to download it on new devices. It is a shame because it was a 2011 Durango app that has more complete and better info that when you pick Durango from the Drive Dodge app.
Old 07-14-2014, 07:39 AM
FSTDANGO3's Avatar
FSTDANGO3
FSTDANGO3 is offline
Hey Shelby can you send me a link of sorts to download that.
STEVE
Old 07-14-2014, 10:51 AM
shelbymopar89
Try this
Check out "Dodge Durango Vehicle Info"
https://play.google.com/store/apps/details?id=com.tweddle.oip.durango
Old 07-14-2014, 01:03 PM
FSTDANGO3's Avatar
FSTDANGO3
No longer available...
Old 07-14-2014, 03:02 PM
shelbymopar89
Hmm, that is odd. Like I said I can go to my playstore download history and down load it (just did on my new tablet) but other than my history it appear to be nonexistent. ..
Old 07-16-2014, 02:51 PM
alfie43's Avatar
alfie43
alfie43 is offline
Scroll through the instrument cluster display with the up/down buttons on the left side of your steering wheel. When you get to "Vehicle Info", select with the center button and scroll up/down again until you see the "Oil Life Remaining" info.
If you are at 6K, you have about 4K until your next oil change.
Alfie
Old 07-17-2014, 08:56 AM
bjballar41's Avatar
bjballar41
Even tho its a 2011 it should be in there? I've looked in there. Has everything but percentage.
Quick Reply: how to check oil percentage
