[4th Gen : 01-07]: ABS Pump Module
Old 07-12-2014, 09:40 PM
mattd860's Avatar
mattd860
mattd860 is offline
Default ABS Pump Module
As some of you know I just inherited a 2002 Dodge Grand Caravan that needs some work. However, my neighbor who has a decent 2001 Chrysler Town & Country told me I can have his for parts for $300 solely because the ABS Pump Module has gone bad and he is done trying to fix the van (he just spent hundreds on brakes, brand new master cylinder, and tune up). The van runs perfectly (even has ice cold AC) but no brakes. When you press the brake pedal, it goes to the floor without stopping the vehicle. The dealership says it's because the ABS pump is shot since they just put in a new master cylinder and verified there are no other leaks. Does this make sense??? Can this device fail internally rendering the brakes inoperable??
Old 07-13-2014, 02:40 PM
master tech's Avatar
master tech
master tech is offline
Site Moderator & Tech
Did they to bleed the ABS module with a scanner? Or was there any codes in the brake system?
Old 07-13-2014, 03:05 PM
mattd860's Avatar
mattd860
mattd860 is offline
I really dont know. They brought it to a chrysler dealer where her father works as a mechanic so I assume they would do what is required to properly diagnose.
Old 07-13-2014, 10:19 PM
master tech
Try to find out from the father if the ABS module has an internal leak.
Quick Reply: [4th Gen : 01-07]: ABS Pump Module
