engine swap
Old 07-12-2014, 09:29 PM
cg1999's Avatar
cg1999
cg1999 is offline
Default engine swap
I have a 1999 dodge ram 1500 5.9 and the engine blew so i got a deal on one out of a 1996 and i know there are some differences but could some one tell me any specific that needs to be changed so it will work with the 99 and run right im using the 99 intake and keeping its wiring harness and thanks
Old 07-17-2014, 01:34 PM
cg1999's Avatar
cg1999
cg1999 is offline
Default anyone help
Can any one help me
Old 07-17-2014, 02:14 PM
djbucky3's Avatar
djbucky3
djbucky3 is offline
Sort of. #1, do a search for such a thing. I know i have seen many many engine swap threads on here where they have talked about putting an older engine into a 98 or 99. Secondly, try posting this in the second gen section, no one looks here.
Old 07-17-2014, 07:30 PM
jasonw's Avatar
jasonw
jasonw is offline
Site Moderator
Please post in the correct section. Moving you now.
For future reference:
https://dodgeforum.com/forum/dodge-r...ead-first.html
Old 07-17-2014, 11:34 PM
Received 3,168 Likes on 2,922 Posts
Just swap the intake, and the rest of the sensors off the current motor, to the new one. Bolt right in, hook right up.
Old 07-18-2014, 07:32 AM
RDuck's Avatar
RDuck
RDuck is offline
Awshom.
Old 07-18-2014, 12:13 PM
cg1999's Avatar
cg1999
cg1999 is offline
Thanks
Old 07-18-2014, 02:49 PM
AtomicDog's Avatar
AtomicDog
AtomicDog is online now
When you perform the intake swap, be sure to fix the plenum gasket/plate issue on the intake that will ultimately end up on the motor that will be in the truck.
Quick Reply: engine swap
