Dodge Journey Dodge Journey forum for discussion on the popular Dodge Crossover and CUV.
2009 dj 3.5 sxt
Old 07-12-2014, 05:50 PM
awpmech's Avatar
awpmech
awpmech is offline
Exclamation 2009 dj 3.5 sxt
My Journey is acting like its running out of fuel when you accelerate. I would have to put it in neutral shut the engine off and coast then start it back up and it would be fine for awhile. Now that does not work. Now I loose all throttle response and the rpms stay at 500. I did take it to the dealer but they say they cant duplicate the problem. I hooked up my scanner and I get two codes PO171 and a PO174 as a potential code. Any help would be helpful
Old 07-12-2014, 07:37 PM
awpmech's Avatar
awpmech
awpmech is offline
I did check the o2 senors all but one stay steady. o2s21 changes from .760 to .008 and in between and it does it quickly
Old 07-14-2014, 09:12 AM
DodgeCACares's Avatar
DodgeCACares
DodgeCACares is offline
awpmech,
I'm sorry to learn of the issue you're experiencing. Have you had a chance to discuss the fault codes set with your dealer?
The PO171 and PO174 codes are associated with the fuel delivery system. In addition to O2 sensors, the Powertrain Control Module (PCM) is also involved.
Old 07-15-2014, 05:40 PM
awpmech's Avatar
awpmech
awpmech is offline
I actually found that the codes come up when you just put your foot to the floor Until the engine dies then those two codes come up but if you just ease onto the throttle when it starts acting up most the time it will clear itself up a little one fine other than that you gotta shut it off and started back up again when it does it the coast don't come up
Old 07-16-2014, 11:29 PM
steak59's Avatar
steak59
steak59 is offline
Possibly low fuel pressure, bad fuel pump? You really just have to hook up a fuel pressure gauge to check it. But these cars requires some inline adapter to fit, it has not shrader valve.
Quick Reply: 2009 dj 3.5 sxt
