Fuel pump issue with results
Old 07-12-2014, 04:44 PM
Indy500Clone's Avatar
Indy500Clone
Indy500Clone is offline
Default Fuel pump issue with results
OK so i come out this morning to test fuel supply on truck,
i drove it last night, so there should be a reading immediately without turning the key on correct? cause the gauge read zero which tells me the regulator isnt holding pressure?
but anyways
So when i turn the key i hear the pump do nothing really, and the gauge barely moved. cycled key couple more times then pressure was rising but when i turn key off the pressure immediately drops ,
will post a video if someone needs
while truck is on it flucuates between 48-50 really bad, when i gas it while running it drops to 46 , and when i kill the truck pressure goes back to zero instantly,
gas looked a little discolored ( tanish ) coming from my drain line.
when i turn key back on after test, takes 3-4 cycles to reach full pressure.
is this a pump/ regulator/ clogged fuel rail problem?
my truck has Long start issues, bad fuel economy and miss's bad espcially when low on fuel and when it first starts up, ( i have done new Coil/cam censor/ cap/rotor/wires//batter / plugs
(gutted catalayic converter ) new oxygen sensors, new IAC
Old 07-12-2014, 04:52 PM
Indy500Clone
the truck is a 1996 dodge ram 4x4 sport. 5.9 magnum , if that makes a difference, truck only has 95,000 miles so im confused on why this pump is bad already or what it is any advice on what to do next would be great. im also going to find a delphi fuel pump assembly also .
Old 07-12-2014, 05:11 PM
xjarhead69's Avatar
xjarhead69
xjarhead69 is offline
Sounds like the regulator is bad, which means new fuel pump because it's all one unit.
Dave
Old 07-12-2014, 05:19 PM
Pump may be going in any event....
I think you have more than one problem though.
Old 07-12-2014, 06:02 PM
Indy500Clone
thanks guys , ok so ill get a pump, what other problems do you think i have? im willing to do anything i can to fix this truck i love my dodge
Old 07-12-2014, 06:23 PM
Indy500Clone
also this is the pump im going to get. https://www.rockauto.com/catalog/mor...858&cc=1095702
when the truck is Full of gas, it has a easyier time starting doesnt really bog or misfire, when its on E is when i really feel it running like crap, turn a corner and from take off it boggs (sounds like misses )
possible the injectors are bad?
Old 07-12-2014, 07:35 PM
If you like changing fuel pumps, go ahead and get the airtex. If you only want to do it once, get a delphi, or denso pump. Airtex sucks. They have a horrible reputation. I wouldn't install one at gunpoint.
Old 07-12-2014, 08:03 PM
Indy500Clone
I made a mistake when i sent that link lol, in my first post i even said delphi my mistake. https://www.rockauto.com/catalog/mor...375&cc=1095702
would you happen to know what other parts should i expect to be replaced after this issue or problems i may run into? I don't like dropping tanks personally lol
the pressure doesn't hold at all, even when priming before start test gauge shows it instantly drop to 0 .
Old 07-12-2014, 08:48 PM
Everything is in the pump unit. Including the gas gauge. Should be all ya need. Although, while the tank is out of the way, wouldn't hurt to have a look at the rear brake line.
Quick Reply: Fuel pump issue with results
