ram 1500 grinds in first,second and third gear
Old 07-10-2014, 12:47 PM
davesredneckwine's Avatar
davesredneckwine
davesredneckwine is offline
Exclamation ram 1500 grinds in first,second and third gear
i have a 1994 ram 1500, 5.2, 5 speed, 4x4, with a 4 inch suspension lift.
the clutch feels fine, no slippage, but it grinds in the first three gears, fine in fourth and fifth. i was told that it was probably a throw out bearing but im thinking not. ive done some research and am thinking it might be the transfer case output shaft bearing. any thoughts on this? and is there a kit to rebuild a transfer case? im afraid that there is damage because of driving it like that. thanks for any help.
Old 07-10-2014, 02:21 PM
Rescue35's Avatar
Rescue35
Rescue35 is offline
Sounds like bad synchronizers in your transmission.
Old 07-10-2014, 03:57 PM
Trans gears grinding has nothing to do with t-case. I agree with Rescue35. Trans issue.
What size tires are you running, and what gear ratio in the axles?
Welcome to DF!
Old 07-10-2014, 06:26 PM
davesredneckwine
im running stock tires right now, i think 275 16s, and it only makes noise when under pressure, completely gone when not on the throttle or gearing down. never any problems going into gear and i thought when the syncros go it will grind going into gear. i will look at the rear end and let you know what gears i have. thanks, just trying to fix the right part
Old 07-10-2014, 06:27 PM
Does it grind when you shift? Or only when actually applying power thru the driveline? Growl while driving????
Have you checked the snap ring on the t-case output shaft?? Fluid levels up to snuff?
Old 07-10-2014, 06:36 PM
davesredneckwine
no noise when i shift, only when under power, i will check fluids. is there an easy way to check the output shaft?
Old 07-10-2014, 09:22 PM
Gotta drop the driveshaft, and pull the tail housing off the t-case. Not too bad of a job.
Old 07-12-2014, 01:10 PM
davesredneckwine
i can get a 5 speed trans and tcase out of a 2002, will it work? i am going to pull the tail shaft off and take a look but it sounds pretty bad.
Old 07-12-2014, 04:39 PM
What engine is it behind?
Old 07-13-2014, 11:46 AM
davesredneckwine
the donor rig has a 5.2, same as mine
Quick Reply: ram 1500 grinds in first,second and third gear
