Steering Knuckle Install???
Old 07-03-2014, 11:54 AM
dahr85's Avatar
dahr85
dahr85 is offline
Default Steering Knuckle Install???
I'm trying to install the steering knuckle after replacing the ball joints on my 1996 Dodge 2500 (2WD). I can get the lower ball joint nut started but the upper ball joint stud won't reach far enough thru the steering knuckle hole to get a nut started. I have the lower control arm jacked up also. I double checked and my replacement ball joints have the same length studs. And it's not that the upper ball joint stud is too big in diameter.
Is there a trick to this?
Old 07-03-2014, 12:32 PM
Get a piece of board, and a hammer. Use the board as an 'insulator', and use the hammer to get the joint down far enough into the knuckle to get a nut started.
Welcome to DF!
Old 07-03-2014, 12:59 PM
dahr85's Avatar
dahr85
dahr85 is offline
Thanks I got it! It was just the angle that the ball joint studs were at. Dang they were tight! I used a block and hammer to get them into the right position and was able to get a nut started...
Old 07-03-2014, 03:07 PM
Cool.
And saved yourself a pile of money on labor too. Still may want to take it in for an alignment when you are done.
Quick Reply: Steering Knuckle Install???
