cant find the ambient air temperature sensor
Old 07-02-2014, 06:10 PM
Behemoth's Avatar
Behemoth
Behemoth is offline
Default cant find the ambient air temperature sensor
my check engine light is on my 1999 dodge ram 1500 5.2L V8 and the diagnostic says its the ambient air temp sensor but i cant seem to locate it i changed a few other sensors such as the air charge temp sensor but i need this one to remove my check engine light any ideas as to were it may be
Old 07-02-2014, 06:23 PM
Spillage's Avatar
Spillage
Spillage is offline
It's on the front right of the keg, behind the alternator.
Old 07-02-2014, 06:25 PM
Behemoth's Avatar
Behemoth
Behemoth is offline
is ther a way you can maybe show me a picture of it if at all possible i need to get rid of the engine light to go do my smog
Old 07-02-2014, 06:34 PM
Spillage's Avatar
Spillage
Spillage is offline
Added above
Old 07-02-2014, 06:43 PM
Behemoth's Avatar
Behemoth
Behemoth is offline
this is what i just changed not sure if it was the right one
Attached Thumbnails cant find the ambient air temperature sensor-20140702_153536-1-.jpg
Old 07-02-2014, 06:45 PM
Spillage's Avatar
Spillage
Spillage is offline
That's it...
Old 07-02-2014, 06:46 PM
Behemoth's Avatar
Behemoth
Behemoth is offline
yeah i changed it it was extremely black but my engine light wont come off and it still says the same thing when i run the diagnostics
Old 07-02-2014, 06:54 PM
Behemoth's Avatar
Behemoth
Behemoth is offline
everything i look up tells me its this but cant find this part anywhere
Attached Thumbnails cant find the ambient air temperature sensor-capture.jpg
Old 07-02-2014, 07:10 PM
Received 3,168 Likes on 2,922 Posts
Do you have an overhead console, that displays outside temp? (if so, does it work?) That is what the ambient air temp sensor is for. That feller should NOT set a check engine lite. Verify you are getting five volts to the IAT.
Old 07-02-2014, 07:34 PM
Behemoth's Avatar
Behemoth
Behemoth is offline
how would one verify they are getting 5 volts to it
Quick Reply: cant find the ambient air temperature sensor
