04 1500 misfire #7 open circuit injector #5
Old 06-19-2014, 06:24 PM
Luke M's Avatar
Luke M
Luke M is offline
Default 04 1500 misfire #7 open circuit injector #5
I have a 2004 Ram 1500 4x4 5.7 hemi, 176,000 on truck 12,000 on engine. Tune up done with all OEM parts when engine was replaced (done at Dodge dealer). I have a code for misfire on #7 and open circuit fuel injector on #5. I have done the following, tested spark on all plugs, compression test, leak down test, and noid light test. I am unsure on what I should check next. The truck runs rough at idle and at lower speed load, if I drop a gear and give more throtle it smooths out and runs great. It did this last time also but that time it faild all tests for compresion and leak down on #7 (this is why it has the newer engine). Any ideas please help, I cant afford to throw money at the problem to do trial and error. Thank you!
By the way, new to the forum so, Hi y'all!
Old 06-20-2014, 07:48 AM
Sdupuy01's Avatar
Sdupuy01
Sdupuy01 is offline
I just fixed my 4.7 that had a misfire on #2 cyl. It ended up being the coil pack. Check the connections at the injector to make sure it's not loose or disconnected.
Old 06-20-2014, 08:47 AM
Luke M's Avatar
Luke M
Luke M is offline
Both the coil pack and connections are good, I have great spark from both points on the coil pack. Thank you for the reply! Any other ideas?
Old 06-20-2014, 08:51 AM
TNtech's Avatar
TNtech
TNtech is offline
Site Moderator-Dodge Tech
Welcome to Dodge Forum!
So this is a salvage yard engine?
Old 06-20-2014, 09:26 AM
Luke M's Avatar
Luke M
Luke M is offline
This was a complete reman/rebuild. They started from bare block and put everything new into it to make it a long block.
Old 06-20-2014, 09:34 AM
TNtech's Avatar
TNtech
TNtech is offline
OK, gotcha. I there a reason you haven't gone back to them to get them to fix it? Or was this a while ago?
Anyway, you need to go after the #5 Injector code FIRST. Misfires are subjective, but a circuit code is not, so that's why first. Keep in mind that a malfunctioning cylinder can affect the whole bank (1357) and sometimes both banks. The #7 may be a result of the #5 in other words.
Take an Ohm meter and measure across #5 injector and compare it with a couple more injectors.
Old 06-20-2014, 10:14 AM
Luke M's Avatar
Luke M
Luke M is offline
Now I just have to find my DVOM in my garage that my wife took over for a garage sale! LOL Thank you for a new place to start looking! The engine was done almost 3 years ago, just a little past waranty! :-)
Old 06-20-2014, 11:35 AM
Luke M's Avatar
Luke M
Luke M is offline
I got a 12.4 on #5 and the others that I checked ranged from 12.0-12.3
Old 06-20-2014, 01:06 PM
Izero's Avatar
Izero
Izero is offline
That is within tolerance.
Might be time to pull the valve cover and check the valve springs.....
What did you compression test come back as?
Old 06-20-2014, 01:27 PM
Luke M's Avatar
Luke M
Luke M is offline
150psi and held (dropped maybe 2-3psi) for 20 minutes (while I ate lunch). It was within the same tolerance as the other cylinders (between 140-160 aprox). There was no pinging in the valve train and it does have the upgraded springs installed already. I am going to take it to the dealer for diagnostics, it could be something as simple as a cracked or corroded wire that I would not be able to track down. I cant figgure it out!
Thank you all for the info and insight!
Quick Reply: 04 1500 misfire #7 open circuit injector #5
