Third Brake Light CAN BUS (Multiplex)???
2002 Dodge Durango SLT Plus, 4.7 L., two (2) wheel drive, 45RFE Trans, 186,000 miles.
OK I have searched all over and Googled until my goggles have ceased to function. I want to replace at least the third brake light bulbs ...... also known as the high mount brake light bulbs with LEDS. Can anyone tell me if these bulbs are on the Multiplex network ....... also known as or similar to a CAN BUS network?
I would also like to replace the marker lamps on this dodge with LED bulbs. Any possibility someone has a wiring diagram showing the bulbs the Body Control module can "see" and pulls information from??
I know these circuits can be controlled the body control module because I have seen them blink furiously when my body control module went out. Does the module or any other computer check the resistance or loads on these circuits. This would be really important if the ABS system reads the brake lights. Although the more think about it I would get this signal straight from the brake switch. But you never know anymore. Hence I am asking for your help.
Thanks
Thanks
Thanks
Thanks
Make sure the replacement LED's are red... the white ones going thought the factory lens make it come out really dim... I would buy one of the LED replacement of Ebay for like 30 bucks.
I went through a ton of different pnp led bulbs to find ones that were bright enough to use in my 3rd brake light. This style led was just as bright as the incandescent bulb it replaced. http://www.ebay.com/itm/2pcs-of-T10-Wedge-LED-Trunk-Cargo-Light-9-Flux-Red-Light-Bulbs-One-Pair-2825-/191205357799?pt=Motors_Car_Truck_Parts_Accessories&hash=item2c84ba38e7&vxp=mtr
And oldschool is absolutely correct about wanting to use the same color led as the lens they're shining through. Long story short, leds don't produce the entire light spectrum like incandescents do, so for example a white led produces almost no red light to make it through the lens.
