Monroe Struts
Old 06-16-2014, 10:44 PM
Z-809's Avatar
Z-809
Z-809 is offline
Default Monroe Struts
I need struts for my 2007 Dakota 4x4 so What do you guys think of Monroe Suspension Strut and Coil Spring Assembly #171100. Will they be as good as the original Mopar ones!!!
Old 06-17-2014, 08:16 AM
dakotaff's Avatar
dakotaff
dakotaff is offline
No way 'as good'. They kick a$$ over the OEM junk struts. Just get them...the Monroes.
They will be a huge improvement.
Old 06-17-2014, 08:21 AM
jkeaton is offline
Monroe is way better than OEM. You really dont need the added expense of the coil spring, factory ones are ok. Its the OEM strut itself that sucks.
Old 06-17-2014, 08:43 AM
flywithnelson's Avatar
flywithnelson
flywithnelson is offline
I went with there quick struts. There a lot better then mopar. Good luck getting that bolt out of that rubber bushing.
Old 06-17-2014, 03:34 PM
modernmuscle's Avatar
modernmuscle
modernmuscle is offline
I just soaked mine with wd-40! I heard you can get away with heating them up, but not sure how you would do that and not burn the rubber.
Old 06-19-2014, 11:37 AM
rodslinger's Avatar
rodslinger
rodslinger is offline
I keep hearing about this. I just changed the struts on my 2011 (35k miles) and both lower bolts came right out. Is it age related or just something with the trucks further north.
Old 06-20-2014, 11:23 AM
Z-809's Avatar
Z-809
Z-809 is offline
Thkx for the replys and i went with the Monroes!!!
Old 06-20-2014, 01:34 PM
i.who.made.you's Avatar
i.who.made.you
i.who.made.you is offline
It's age, rust, and over torque.
If you hit them with the WD-40 rust penetrating spray and just work at it heating isn't necessary. If you do need to hear it start with an induction heater not a heat gun.
Quick Reply: Monroe Struts
