Bad A/C coil... HELP!
Old 06-07-2014, 03:59 PM
RamblerReb's Avatar
RamblerReb
RamblerReb is offline
Default Bad A/C coil... HELP!
I need a field coil for my A/C compressor and I can't get one from Dodge. Anybody got one for a reasonable price, or a source for one? I'd rather buy from someone on the forum than from a salvage yard in Podunk, Whereverthehell off Ebay.
Thanks!
Old 06-07-2014, 09:50 PM
onemore94dak's Avatar
onemore94dak
onemore94dak is offline
I assumed you mean for the listed 93 Dak
http://www.factorychryslerparts.com/...=AC+field+coil
Old 06-07-2014, 10:28 PM
RamblerReb's Avatar
RamblerReb
Thanks! Unfortunately, $292 is more than I was looking to spend. I could get a complete reman on Ebay for $250 or so. I was just hoping someone might have a parts truck with a coil they'd be willing to part with.
Old 06-07-2014, 11:24 PM
RamblerReb's Avatar
RamblerReb
Although, now that I look at that again, I think that's the evaporator coil in the diagram. I mean the field coil on front of the compressor which locks the pulley to the shaft to start the compessor compressing.
Sorry if I wasn't clear.
Old 06-08-2014, 12:42 AM
RalphP's Avatar
RalphP
RalphP is offline
That would be called the A/C clutch coil then. Or ideally the entire clutch assembly.
If you do go to the boneyards, take a 12V battery (I take a "Jump Start" kit with me) and use that to test the coil. Then I'd get the entire clutch assembly.
RwP
Old 06-08-2014, 03:27 PM
RamblerReb's Avatar
RamblerReb
RwP
Good idea!
The clutch coil is also called the field coil, since it generates a magnetic field to lock the pulley and shaft, but I could have been clearer, as I said.
Quick Reply: Bad A/C coil... HELP!
