2500 springs ?
05-03-2014, 11:12 PM
on
2500 springs ?
Hey guys I found a pair of front springs off a 96 ram 2500 gas 360 and was wondering if these would give any lift to my truck at all?
05-03-2014, 11:17 PM
Yep inch and half to 2 inches
05-03-2014, 11:21 PM
on
Alright thanks and he said the truck had 116k miles before replacing. He said he replaced them with longer springs to help fit his 35's along with a steel front bumper and hitch. Should these still be fine or will they sag?
05-04-2014, 12:00 AM
Sounds like lift springs. You don't won't those. You would want the the stock gas springs if you want to level.
05-04-2014, 12:22 AM
on
They are stock springs, he put in a longer spring on his current ride. I'm just afraid they might be sagging because of age. They're $20 so if they are its not a problem.
05-04-2014, 12:39 AM
Oh ok he's replacing his springs.
Yep I would grab them up reall quick. Those springs at identical to to the ore springs which come from factory with a 2in lift. Or something along those lines.
20 bucks is a still
05-04-2014, 01:36 AM
If the springs came off a 96 truck, then they have long sense settled in and wont sag if you put them on your truck.
For $20. dollars that's a good deal.
05-04-2014, 08:46 AM
on
Hey guys I'll be omw to get the springs here shortly and I cant wait to put them on. While I'm at it I figured I'd go ahead and replace the 15 y/o front shocks. I've been looking at these
http://www.summitracing.com/search/d...t&autoview=SKU. My question now is which would be the correct one and are they any good?
05-04-2014, 10:56 AM
I'm not really seeing any difference between the two...... IS there any difference? Valving? Something?
05-04-2014, 11:10 AM
