replaced engine now wont start
Old 04-24-2014, 11:19 PM
tmpeyton25's Avatar
tmpeyton25
tmpeyton25 is offline
Default replaced engine now wont start
I have a 2004 dodge ram 1500 with a 4.7 i replace the engine a while ago and now it wont start im getting fuel to the fuel rail and spark. it cranks over fine just wont take off even tryed spraying starting fluid in it still wont take off i have ran out of ideas thank for your time.
Old 04-25-2014, 08:26 AM
Izero's Avatar
Izero
Izero is offline
Sounds like you need to get a scanner hooked up to it and see if you're throwing and DTCs during the start cycle....
Really difficult to troubleshoot a no-start on a brand new motor, but I'd start by checking each and every single connection on the main harness....
Old 06-16-2014, 06:56 PM
tmpeyton25's Avatar
tmpeyton25
sorry been working alot havnt got back on here i recently replaced the ecm checked every wire after replacing ecm i now have power to coils but now have no spark i wants to hit on starting fuild but still nothing
Old 06-16-2014, 09:22 PM
thunderhawk09's Avatar
thunderhawk09
thunderhawk09 is offline
Id check Cam sensor Under P side Valve Cover If There Has Been A Magnet Gotten close to it. it could give you the no start issue
Old 06-17-2014, 02:30 AM
Prismatic's Avatar
Prismatic
Prismatic is offline
Tone rings match up?
Old 06-17-2014, 03:34 PM
tmpeyton25's Avatar
tmpeyton25
replaced cam and crank senor each one diff brand and still nothing
Quick Reply: replaced engine now wont start
