Spark plug wire set V10
Old 04-14-2014, 05:29 PM
STiRocket's Avatar
STiRocket
STiRocket is offline
Default Spark plug wire set V10
My 2001 Ram 2500 is in need of new spark plug wires. Do you guys just buy OEM wire sets from a dealership, or are there better wire sets to be had elsewhere? Search wasn't too helpful...
Mark -
Old 04-14-2014, 05:39 PM
Received 3,170 Likes on 2,923 Posts
Check your local auto parts stores, and see what they have in 'performance' wire sets. The dealer wires are ok, but, there are better to be had... for less money..... elsewhere.
Old 04-14-2014, 06:42 PM
STiRocket's Avatar
STiRocket
Thanks for the suggestion, I just didn't know if there was something special about them. Yeah, my dealership wants $150.00 for them and he would have to order them in. My truck is a 2001, but it only has 50K miles on it. I bought it in 2009, and have only put a few thousand miles on it myself. But the plug wires are still 13 years old, and one was rubbing on the exhaust manifold and would intermittently short out. So I decided it was time to replace them. Spark plugs only have 50K on them so they may still be good, I'll have to pull one and take a look. I bought a travel trailer last November, so the wife and I are starting to put some miles on the truck now. I replaced the battery this last trip too.
Mark -
Old 04-14-2014, 08:08 PM
I think those are standard plugs in there.... (not entirely sure on that....) I would definitely pull a couple, and have a look.
Old 04-14-2014, 10:05 PM
JTB488's Avatar
JTB488
JTB488 is offline
I put this on mine. They are a little thicker than the stock ones, so you have to leave the plastic loom cover off. http://www.summitracing.com/parts/ta...model/ram-2500
Old 04-14-2014, 10:41 PM
STiRocket's Avatar
STiRocket
I saw those at Summit Racing, and I measured my stock ones, they're 7.5mm. So do I understand correctly that you're saying that 8.2mm won't fit in the plastic loom cover? Dang, a whole mm is less than .040"!!! Must be a tight fit. I'm not sure how attached I am to that loom cover...
Mark -
Old 04-14-2014, 11:26 PM
AtomicDog's Avatar
AtomicDog
AtomicDog is offline
Old 04-15-2014, 03:01 AM
STiRocket's Avatar
STiRocket
I didn't see those, would .2mm be enough to fit into the plastic loom cover that JTB488 was talking about???
Mark -
Old 04-15-2014, 03:10 AM
STiRocket's Avatar
STiRocket
I have read a few threads that were horror stories about removing spark plugs from this engine. Sounds like they rust in place, the one I looked at tonight had rust on it. I was trying to see the brand and model of plug, guess I'll have to pull it to see what I'm up against. Are there good suggestions about pulling these plugs? Should I like spray WD-40 on them the night before, or what?
Mark -
Old 04-15-2014, 06:18 AM
AtomicDog's Avatar
AtomicDog
I'd spray some good penetrating oil on them, such as PB-Blaster, Kroil or home brewed acetone/transmission fluid mix. Let it sit overnight and come back and try pulling them.
Quick Reply: Spark plug wire set V10
