Old 08-05-2015, 09:20 PM
How-Tos on this Topic
Last edit by: IB Advertising
Browse all: Cooling System Guides
Print Wikipost
Waterpump change, suggestions?
Old 04-05-2014, 09:47 AM
stenerson's Avatar
stenerson
stenerson is offline
Default Waterpump change, suggestions?
My waterpump is leaking...It's not coming from the thermostat housing , (It was last year and a new gasket fixed that)...
Anyways, I figure at 197K I might as well replace it and play it safe.. I ordered an OEM waterpump and new thermostat.. I figured it's time to change the belt (never changed). I got a new belt tensioner.. I think there are two other pullys which I probably should change ? The idler pulley and idler assembly. Numbers 5 and 9 on this diagram..Any other suggestions? Am I missing anything?
Old 04-05-2014, 10:53 AM
Gone Fishin's Avatar
Gone Fishin
Gone Fishin is offline
hoses...
Old 04-05-2014, 11:11 AM
stenerson's Avatar
stenerson
Originally Posted by Gone Fishin
hoses...
You think it's time to replace the hoses?
Old 04-05-2014, 01:09 PM
HemiMoparGuy1981's Avatar
HemiMoparGuy1981
HemiMoparGuy1981 is offline
Water pump is definitely common on these, I replaced mine, thinking it was leaking, but it was just the thermostat gasket...unfortunately, I bought the pump at an Auto Value out of town with the intent of changing it out at my uncle's house, but ended up going home to do it...the Auto Value's near my house wouldn't return it, cuz they are independently owned , so I just decided to throw it on since I wouldn't be back near the one I bought it from for quite some time. So I ended up with a perfectly good water pump that I have sitting on my shelf, and I relaly didn't have the money for it in the first place...so I would make sure you know for a fact it is the pump. If you're replacing idler pulleys just because, and at 197k, I'd put a new tensioner (most come with new pulley as well) on it...it would be more important than the idler pulleys, as it is a spring that keep tension on the belt, 197K, spring has to be getting tired.
Old 04-05-2014, 01:21 PM
stenerson's Avatar
stenerson
Thanks HemiMoparGuy1981.. I also had the thermostat housing leak a couple years back. I already pulled the plug on replacement parts, figured while everything was out I'd replace other easy stuff.
Old 04-05-2014, 05:22 PM
Gone Fishin
Well with 197K, and the fact that you're draining the system anyway, why not? May save you a real PIA later if an old one lets go in the middle of rush hour traffic on your way home on a Friday afternoon
Old 04-05-2014, 08:35 PM
stenerson's Avatar
stenerson
Good point thanks.
Old 04-06-2014, 07:01 AM
Gone Fishin
Stuff like that always seems to happen when you're in the middle lane of a 5 lane freeway doing 65 mph and the traffic is packed bumper to bumper, and now you have a wash of anti-freeze all over the windshield---------!
Old 04-06-2014, 08:49 AM
abarmby's Avatar
abarmby
abarmby is offline
Good time to flush your cooling system as well and complete it's overhaul.
Use factory HOAT coolant.
Also replace the idlers as well.
Collapsing needle bearings cause one heck of a racket and I've also seen several pulleys take a dump and grenade, throwing the belt and destroying the radiator.
For $25 or so for the pulleys when your this far in, is a no brainer.
Cooling system would be then almost fully serviced.
Good piece of mind.
Al
Old 04-06-2014, 12:58 PM
stenerson's Avatar
stenerson
Good piece of mind.
Al
Thanks.. I got a new tensioner that comes with the pulley. And I have to get the 2 other idler pulleys (nubers 4 and 9 in the diagram I posted).
Quick Reply: Waterpump change, suggestions?
