1995 360 Water Pump Bolt Placement
Old 04-03-2014, 10:01 AM
Phillip_Green's Avatar
Phillip_Green
Phillip_Green is offline
Default 1995 360 Water Pump Bolt Placement
Hi guys, Im new here and to this truck. Im replacing the water pump and my bolt sequence got scrambled last night. I cant find a diagram of which go where (short/long). Can someone help? Ive been reading the forums quite a bit since starting on this truck and decided to register. Thank you!!!
Old 04-03-2014, 11:10 AM
Moved this to the tech section for you.
Welcome to DF!
There are four long bolts that go thru the pump, timing cover, and into the block, where the water passes thru. I think the rest are all pretty much the same length.
Old 04-03-2014, 06:44 PM
Twmays's Avatar
Twmays
Twmays is offline
Agreed. The four long bolts form a very neat rectangle around the center of the pump; the other ones are in goofy angles compared to that rectangle.
Quick Reply: 1995 360 Water Pump Bolt Placement
