fuel pressure and hose size
Old 03-19-2014, 08:37 PM
kussy99's Avatar
kussy99
kussy99 is offline
Default fuel pressure and hose size
What is the fuel pressure for a 1999 ram 1500 v8 5.9L 360 and the inside diameter of the fuel hose?
Old 03-19-2014, 08:52 PM
Received 3,174 Likes on 2,927 Posts
3/8ths line, (not sure if that is ID, or OD) Should be around 49PSI at idle.
Welcome to DF! Cruise on down to the second gen ram section. LOTS of knowledgeable folks there.
Old 03-22-2014, 04:12 PM
kussy99's Avatar
kussy99
kussy99 is offline
Default 99 doge ram 1500 5.9 fuel line
Is the fuel line on a 99 dodge ram 1500 sport 5.9L the 3/8 silver metal line that runs down the drivers side of the frame?
Old 03-22-2014, 05:04 PM
Trace it starting from the tank. I do believe it is flexible line, to metal line, back to flexible, and then the quick-connect at the fuel rail.
Old 03-22-2014, 05:43 PM
Johnn123's Avatar
Johnn123
Johnn123 is offline
3/8" line, should be 48-50 psi. Not sure what the materials are though at what locations.
Old 03-22-2014, 11:14 PM
kussy99's Avatar
kussy99
kussy99 is offline
The line starts from somewhere on the tank, but is in between the frameand the tank and cant get to it. All I can find is two metal lines one 3/8 one much smaller. I'mtrying to put an in line fuel filter on.
Quick Reply: fuel pressure and hose size
