Noise in the steering
Old 03-18-2014, 04:49 PM
i4got68's Avatar
i4got68
i4got68 is offline
Exclamation Noise in the steering
Trying to figure out what's up with my steering, the truck shakes as you speed up and it does pull to the right. I took a video of the wheel when it was shaking.
Can you hear the sound when I let go of the wheel too?
It's the truck in my signature and it does have the 318.
Old 03-18-2014, 08:55 PM
i4got68's Avatar
i4got68
i4got68 is offline
Nobody has any idea at all? I myself was thinking it could me the tie rod ends or ball joints
Old 03-19-2014, 02:08 PM
BrandonBuc'em's Avatar
BrandonBuc'em
BrandonBuc'em is offline
sounds like tie rods.
Old 03-19-2014, 02:51 PM
chromed95's Avatar
chromed95
chromed95 is offline
have someone turn the wheel while you look at the steering components for excessive play. How/s the alignment on that? Ball joints good?
Old 03-19-2014, 05:59 PM
i4got68's Avatar
i4got68
i4got68 is offline
I did get to thinking that it couldnt be tie rod ends because it would veer off a little more when I hit bumps
Old 03-19-2014, 10:06 PM
i4got68's Avatar
i4got68
i4got68 is offline
The alignment is good. And I know this because both front tires have even wear on them. As for the ball joints, my buddy jacked up the pass side front and put a bar under the tire and had a little bit of play. But the shaking in the steering wheel is very noticeable just riding in it. My girlfriend definitely notices it in the passenger seat.
Old 03-20-2014, 01:36 PM
chromed95's Avatar
chromed95
Not sure if a little play will cause a shake, but its possible. Ideally there should be none. has one or more of your ties thrown a wheel weight? Generally, if someone feels a shaking or vibration in the seats, tire balance can be to blame. You'll feel it in the steering wheel too.
Old 03-20-2014, 02:28 PM
Shake in the steering? Rotate your tires, see if the shake moves.
Old 03-20-2014, 04:14 PM
i4got68's Avatar
i4got68
i4got68 is offline
Its noticeable all around the truck. Like, I have a CB on the dash and the mic hung up on the center roof cubby and the wire shakes along with the CB. I can feel it in the steering wheel and when I do turn the wheel when sitting still, there's more play than it should be.
Old 03-20-2014, 09:24 PM
i4got68's Avatar
i4got68
i4got68 is offline
Uploading a video of the wheel making noises when the truck is sitting still
Quick Reply: Noise in the steering
