Re-gear question
Old 03-17-2014, 07:30 PM
Nate_rs's Avatar
Nate_rs
Nate_rs is offline
Default Re-gear question
So I'm currently on 33s coupled with stock gearing and it is terrible. I want to regear my axles this year but I'm not sure how low to go. The 33s have 6,000 miles on them and when I replace them I'm getting 35s, maybe ~36s. So, my question is, would 4.88s be alright on 33s until I replace them? Would that just be overkill? Any harm to be done? Thanks for your input!
Old 03-17-2014, 07:40 PM
Matt Nickerson's Avatar
Matt Nickerson
Matt Nickerson is offline
4.56 if you drive highway at all, 4.88 if ya don't
Old 03-17-2014, 07:43 PM
Nate_rs's Avatar
Nate_rs
Nate_rs is offline
About 30% of my driving is on the highway
Old 03-17-2014, 08:21 PM
4.88s and 33's would absolutely suck on the free way. Pushin' 3 grand at 75 MPH. Better own stock in an oil company.
Old 03-17-2014, 09:17 PM
Nate_rs's Avatar
Nate_rs
Nate_rs is offline
Haha yeah, I figured as much. I'll probably end up going 4.56. Do you know if 4.56 is similar to stock tire size and gear setup as far as power? Or does it feel more torquey than stock?
Old 03-17-2014, 09:20 PM
4.56 coupled with 35 inch tires would have RPM's right around stock values for any given speed. (and that's what we generally recommend for 35's.) For 33's, you would run a bit higher RPM on the freeway, but, you will LIKE it around town.
Old 03-17-2014, 09:30 PM
Nate_rs's Avatar
Nate_rs
Nate_rs is offline
And I suppose 4.88s and 35s would be similar to 4.56s and 33s?
Old 03-17-2014, 09:45 PM
AtomicDog's Avatar
AtomicDog
AtomicDog is offline
I'm running 33's (285/75/16) and plan on going to 4.10s front and rear. I think its a great compromise for around town, highway and towing, not to mention gas mileage..
I have 3.55s now and the truck is pretty sluggish from a dead stop.
Old 03-17-2014, 09:53 PM
Nate_rs's Avatar
Nate_rs
Nate_rs is offline
Mine's fine from a dead stop, really. Just an absolute dog on the highway..
Old 03-17-2014, 09:59 PM
Nate_rs's Avatar
Nate_rs
Nate_rs is offline
So I searched around and found the ratio for 4th gear in our transmissions, which happens to be .69. Then I went to this (http://www.crawlpedia.com/calculators.htm) site and used their RPM calculator and found that with 4.88s and 35s at 70 MPH the engine speed is ~2263, which seems good to me. Not too high, and plenty of power right in there.
My question is, is this a reliable calculator to go by? Can I trust that it'll be somewhat close to that? Or is that somehow off or did I calculate something wrong.
Quick Reply: Re-gear question
