? weird contraption behind rear driver tire
Old 03-17-2014, 06:18 PM
96ramcj's Avatar
96ramcj
96ramcj is offline
Default ? weird contraption behind rear driver tire
does anybody know what this thing is on the frame rail behind the rear driver side wheel on my 99 ram 2500 ? its leaking brake fluid.
Old 03-17-2014, 06:30 PM
stewie01's Avatar
stewie01
stewie01 is offline
proportioning valve?
Or is that on the pumpkin?
Old 03-17-2014, 06:32 PM
kejobe's Avatar
kejobe
kejobe is offline
I think it's supposed to adjust brake pressure to the rear wheel depending on the weight loaded. Or something to that order.
IIRC, people have bypassed it with no ill effects, but I'm not sure.
Old 03-17-2014, 06:38 PM
kejobe has the right of it. Dodge even did away with them, as they were kinda problematic. Bypass it, and get rid of it.
Old 03-17-2014, 06:58 PM
96ramcj's Avatar
96ramcj
96ramcj is offline
thanks for your help guys. I found all kinds of info about bypassing it on the internet once you gave me the info so I could search.
Old 03-17-2014, 11:01 PM
jpsycoboy5's Avatar
jpsycoboy5
jpsycoboy5 is offline
How in the perfect world does that work? I'm just curious
Old 03-18-2014, 09:12 AM
Gary-L's Avatar
Gary-L
Gary-L is offline
In a perfect world, it works quite well.
Hope that helps!
Old 03-18-2014, 09:25 AM
i4got68's Avatar
i4got68
i4got68 is offline
My trucks from 98 and I still have that part from factory. I just recently replaced the reservoir on the rear Axel, lines, and the drums with spring kits, adjusters and the shoes.
Old 03-18-2014, 09:28 AM
Ram Driver's Avatar
Ram Driver
Ram Driver is offline
Its a load sensing proportioning valve, it has an arm attached to the rear axle, the more weight you put in the bed of the truck causes the arm to move at the proportioning valve and that allows the rear brakes to adjust for the added weight.
Old 03-18-2014, 09:39 AM
stewie01's Avatar
stewie01
stewie01 is offline
HA! So I was sorta kinda right
Quick Reply: ? weird contraption behind rear driver tire
