07 or 08
Old 03-09-2014, 09:08 PM
deadeye95's Avatar
deadeye95
deadeye95 is offline
Default 07 or 08
Hey guys trying to decide between a 07 or an 08. Both are diesel's with the 07 being the 5.9 both are also 6 speed manuals. I will be using it to pull a #8000 trailer through Ky. and Tn.
This will be my 1st. diesel and I don't know much about the 2 different engines.
Would like any info pro or con, and also know which you would go with if you were me. Both have app. 100,000 miles and are priced very close to each other.
Thanks for any and all help.
Old 03-11-2014, 03:29 PM
Arctodus's Avatar
Arctodus
Arctodus is offline
That 5.9 is bullet proof and the best years are the 05-07's. Stay away from that 6.7 in the 08.
Old 03-11-2014, 07:48 PM
dirtydog's Avatar
dirtydog
dirtydog is offline
Moderate User
06-08 Trucks are identical in every which way minus the differences of diesel engines. Every other aspect is the same.
As for the motors...I cannot say in regards to diesels, BUT I do know newer diesels are getting their ***** chopped off every year that passes by with emissions garbage.
Old 03-27-2014, 03:11 PM
Brandon Anderson's Avatar
Brandon Anderson
Brandon Anderson is offline
Depends on if you want to do any modifications. Stock, you'll get better MPG from the 5.9L. If you're willing to do a DPF & EGR delete, you'll get better performance and MPG from the 6.7L vs a similarly modified 5.9L.
Old 03-28-2014, 06:18 PM
deadeye95's Avatar
deadeye95
Thanks for the replys guys, I still haven't bought anything.
