4BT swap into 99 sport 1500
got started on this project yesterday, pulled the 360 and the 46re out, took me and a friend less than 1 hr from a complete driving truck to engine and trans sitting on the asphalt, then we hoisted up the 4bt, swaped out the rear adapter plates and bolted a 47re to the back and set it in.
so far we have a few fails and a few wins.... the original driveshaft and crossmember are a perfect fit for the 47re, (this is all 2wd stuff), thats a huge plus, as well as the 6bt vacuum and power steering pumps and the 6bt starter all fit in there, i have to do a little clearencing on the PS pump reservoir as it contacts the injection pump, but its minimal.... the bad news... the factory turbo interferes with the firewall due to the exhaust manifold position, some repositioning of the manifold may work or i will modify a 6bt manifold to work, also wanted to use the 6bt engine mounts but that is a no go with the 6bt pumps, starter, and a/c pump in there, so the factory frame mounts need to come out and i will fab something off the front of the engine
day i bought the running/driving truck for $800
changed tires, wheels, and bumpers
1hr into the tear down
and the 4bt/47re sitting in there
folgers is awsome, plus you end up with a handy sealable bolt bin when you are done
a manual was my very first choice, but found the auto truck so cheap, and also found cheap, complete and rebuilt (says the CL poster) 47re, so i figured why not, i hate autos with a passion, but all 6 of my vehicals are manual, except for the 1948 dodge with a 12v cummins also has a built auto, but the truck is in the process of being built at the moment too, an auto might be a nice change once in a while, but i am hard on them and they tend not to last very long at all when i have control of the skinny pedal
got a little more done over the weekend, but had to do a quick shut down and clean up of the project due to weather, so dont have any pics yet, maby get some tonight
got the shift linkage figured out, had to you the cross shaft linkage(frame to trans) and the arm from the cross shaft to the trans, from the 47re truck.... but had to use the trans bracket from the 46re bolted to the 47 for everything to align correctly, guessing thats part of the difference of the 1500-2500 frames, as i believe the 2500 frame is a bit taller, and the nuetral/reverse switch had a different plug but the switch from the 46 went right into the 47 and all trans electrical pluged in ( my 47re is from a 97 2500)
got all the sepentine system off the engine witch was a industrial and non a/c setup, and installed the dodge 6bt system, witch changes the coolant necks, and gives mounts for the a/c compressor, and the mopar altinator, but ran into yet another issue, the industrial fan hub is different from the dodge hub and the pully contacts the dodge upper water neck, so i have to locate the dodge fan hub witch i believe i already have,
other than that, i just have to pull the engine one more time, remove the factory engine mounts from the frame, install the oil pan and bolt the engine back up one last time to the trans and make the new engine mounts, hook up all the nick nacks and with any luck it will be driveable in a week or two, then it will be time for the twin turbo build, and some performance tuning on the fuel system already got all the stuff to do that too, just wana get it to run and drive before i start to play with it
Here's a few photos
Here you can see the dodge serpentine system minus the fan hub and damper, you can see on the left how close the a/c mount is to the frame, but its not an issue yet
Here is the reason its sitting so far to the passenger side, removing the factory engine mounts from the frame should free up all the room I need
Here is a bad shot of the passenger side mount clearance as it sits
And I removed the water to air after cooler, so I made this plate, next step will be to cut a hole and weld up a pipe to mate up to the factory 2nd gen ram intercooler
got some more done this weekend
pulled the engine back out and fixed the infamous "killer dowl pin" as well as tightened all bolts in side the timong cover
got an 1 1/4 freeze plug to plug the original oil fill tube in the side of the block
removed most of the factory frame engine mounts
cut down a factory 6bt exhaust manifold
and did a little porting
was able to bolt up the gas a/c compressor, and with some bending of the lines, the gas a/c lines will work, the front 2 compressor bolts lined up, but the back ones did not, however there were provisions in the corect location, just had to drill them out and remove a small piece with the die grinder inbetween the holes
got the engine mounted, tho i am not very happy with the brackets, but with the limited tooling i have in the drive way, they will have to work for now
a shot of the turbo all mounted up, couldnt have worked out any better, and its in the exact position as a twin turbo ram so my options for my twin mounting are pretty much endless
got the the aftercooler and condenser in there as well as the gas radiator and shroud, the gas radiator actually fits very nice in there, and got all the heater hoses hooked up as well as 80% or so of the electrical done
