2003 Ram 5.7 Hemi
Old 02-28-2014, 10:04 PM
TJZ_Hemi's Avatar
TJZ_Hemi
TJZ_Hemi is offline
Default 2003 Ram 5.7 Hemi
Truck has been a menace in the last year!!
Had a misfire problem:
Replaced plugs, wires and coils. Problem was a broken spring (Fixed by my mechanic):Replaced all springs in the bank, checked compression and other vitals.
Accel 457S - Plugs
MSD 32039 - Wires
MSD 82568 - Coils
K&N Air Filter (Put in when we bought it in 06)
Shortly thereafter is threw Cam sensor position error so I replaced the sensor. Not 50 miles later is started stuttering again and threw the following errors:
PO315
PO339
PO300
Just as a note, shortly before the cam sensor error all but the rear passenger side turn signals stopped working. The signal switch has been replaced and been through extensive research and testing to no avail yet.
So, before I take it back to the mechanic, anyone want to throw out some more suggestions?
Old 03-01-2014, 04:24 AM
tantofolder's Avatar
tantofolder
tantofolder is offline
My manual says:
PO300- Multiple cylinder misfire
PO339- Crankshaft position (CKP) sensor intermittent
My manual does not have a code PO315. Maybe the new sensor was bad too. Sorry that's all I got. I'm sure more knowledgeable folks will chime in.
Old 03-01-2014, 07:32 AM
Dubl0Vert's Avatar
Dubl0Vert
Dubl0Vert is offline
check your grounds......battery main, fender connection, engine to frame....9/10 times intermittent issues are ground related.
Take back to mechanic....he did not diagnose and fix.....he just threw parts at it and didn't test it.
Old 03-10-2014, 10:48 PM
RacerHog's Avatar
RacerHog
RacerHog is offline
Bad Sensor or the pick up ring came loose.... Causing it not to be able to Phase itself....
Old 03-10-2014, 11:23 PM
p38251's Avatar
p38251
p38251 is offline
Put copper plugs, 5.7 doesn't like fancy plugs.
Quick Reply: 2003 Ram 5.7 Hemi
