5.7 to 6.4 hemi swap
Old 02-28-2014, 09:23 AM
johnpa's Avatar
johnpa
johnpa is offline
Default 5.7 to 6.4 hemi swap
Is it possible to swap my 5.7 for a 6.4. I am sure my axles and tranny can handle it. Is it a major fabrication job or is the 6.4 block similar to the 5.7.
any thoughts
Old 02-28-2014, 10:43 AM
brandt.reuss's Avatar
brandt.reuss
brandt.reuss is offline
things I can think of that would cause issues: weight of new engine ( front ifs torsion bars may need to be beefed up to handle weight. if there was a conversion kit to coil over that would be awesome ), motor mounts ( if they aren't the same then fabrication will be required, if they are the same they still might need to be beefed up), wiring harness and other similar interfaces are more of an obstacle than issue, if you decide to do it I would get a fully dressed engine but you also gotta consider stuff like radiators and will you need a new computer.
it would help to know what year and model vehicle you currently have. I know mopar has sold factory crate hemi's fully dressed in multiple sizes. if you remember the gen 3 srt dodge pickup with the v10 viper engine. a buddy of mine bought a wrecked srt 10 and swapped the engine for his 5.7 and it was a plug and play, everything fit perfectly. only issue was transmission because the srt is standard tranny.
Old 02-28-2014, 01:55 PM
HemiLonestar's Avatar
HemiLonestar
HemiLonestar is offline
Weight of the engine is almost exactly the same. There are other problems you'd run into. Are you looking at crate engine, one out of a new 2500 or out of an SRT?
Old 03-01-2014, 09:57 AM
johnpa's Avatar
johnpa
johnpa is offline
My dodge is a 2006 2500 heavy duty automatic 4x4.
Old 03-01-2014, 10:21 AM
dirtydog's Avatar
dirtydog
dirtydog is offline
Moderate User
Yeah, pretty sure it's the same block, just with bigger sleeves.
Why 6.4L? Bigger isn't necessarily better ya know. It's definitely more expensive!
I would prefer a supercharged 5.7L or a supercharged 6.1L. It would just be cheaper in the end I would think and repairs would be as well.
I believe Arlington wants $18k for a 392 built block..lol
Is it just to say you have a 392? If it's the difference in power over a 6.1L, if you put a lower lift(towing) can in the 6.1L, you'll get much better results for a truck application. They need to rev too high to get their power.
Old 03-01-2014, 01:31 PM
johnpa's Avatar
johnpa
johnpa is offline
I tow a 13000 pound trailer and wanted the extra power. Supercharging is a idea though
Old 03-02-2014, 10:49 PM
HemiLonestar
Wasn't asking about your truck, which engine are you looking at to put into it; the 6.4 out of a car or the 6.4 out of the new trucks?
Either way, you'd be better off stroking your 5.7 out to a 392. then you'd have all the torque you probably need and everything will still bolt up.
Quick Reply: 5.7 to 6.4 hemi swap
