o-ring for water pump inlet tube
Old 02-22-2014, 07:21 PM
Ram Driver's Avatar
Ram Driver
Ram Driver is offline
Default o-ring for water pump inlet tube
Were can I find one of these ?. Ive been searching for a couple of hours and I can find the water pump, gasket, and bypass hose, but not the o-ring for the inlet tube.
Anyone have a link to were I can buy one ?.
Old 02-22-2014, 08:18 PM
Matt Nickerson's Avatar
Matt Nickerson
Matt Nickerson is offline
Either buy another water pump (oring comes with it), get one at a hardware store (measure OD of the inlet tube so you know what size oring to get), or use RTV silicone like I did...holds up just fine,
Old 02-22-2014, 09:07 PM
AtomicDog's Avatar
AtomicDog
AtomicDog is offline
When I replaced my water pump, I replaced the tube, as my original tube was rusty and worn. Here is a link to a new one - it should come with the O-ring:
http://www.partsgeek.com/gbproducts/...FXPNOgodfEwAcg
Old 02-23-2014, 01:54 AM
Ram Driver's Avatar
Ram Driver
I just ordered a new water pump from rock auto, it includes the pump, gasket, o-ring, and pipe.
Old 02-23-2014, 10:01 AM
HeyYou is online now
You can get the whole tube, with the o-ring, from your parts store for about 15 bucks. (in the help section) The o-ring is skinny.... not a standard size. (yep, been there, done that....)
Old 02-23-2014, 02:10 PM
Arde's Avatar
Arde
Arde is offline
Same here. I didn't feel like buying the tube when all I needed was the o-ring, so I did like Matt and used RTV. Been a couple of years ago and still no problem with it.
Old 02-23-2014, 03:57 PM
Ram Driver's Avatar
Ram Driver
I need to have the plenum fixed this summer, so im going to have the timing chain done, as will as the water pump. Im also going to have the oil pump replaced because Ive read a few threads here were oil pumps have failed on higher mileage engines, so I didn`t want to take any chances with my engine having 167000 miles on it, so im having it replaced also.
Old 10-02-2023, 11:11 PM
ronnellbagz's Avatar
ronnellbagz
ronnellbagz is offline
Either you're looking for this: VICTOR REINZ 151118601 (Coolant Pipe O-ring) or FEL-PRO ES72872 (Water Inlet Gasket)
AtomicDog (10-02-2023)
Old 10-03-2023, 06:50 AM
Moparite's Avatar
Moparite
Moparite is offline
This post is 9 years old and the op hasn't been here since 2016!
Quick Reply: o-ring for water pump inlet tube
