hemi head compatibility
Old 02-20-2014, 01:52 AM
link040188's Avatar
link040188
link040188 is offline
Default hemi head compatibility
hey everybody new to the site. so I have come across a 2012 5.7 block from a 2500. I am stripping it down and rebuilding it. I happen to have a pair of heads from a 2003-2008 5.7. I have seen posts about putting newer heads on older blocks with different head gaskets but I need to know about the other way round old heads on new block. I know it seems silly since the new heads flow so much better but this is a budget build to Frankenstein a 5.7 hemi into my 1999 ford ranger. any help you guys could offer would be greatly appreciated.
Old 02-21-2014, 10:43 AM
LU229's Avatar
LU229
LU229 is offline
You`d be ALOT firther ahead by just buying a good complete running engine from a junkyard.
Old 02-21-2014, 02:15 PM
link040188's Avatar
link040188
if I hadn't gotten the block and heads for free you would be right but I work on these for a living. I can rebuild it for 800 dollars in parts. a used motor around me runs about 2000 dollars
Old 02-21-2014, 02:22 PM
dirtydog's Avatar
dirtydog
dirtydog is offline
Moderate User
If you work on these for a living, why can't you determine if they will work or not?
What's the hold up? Or did I miss something?
Old 02-21-2014, 03:28 PM
link040188's Avatar
link040188
swapping old heads onto new motors is not something Chrysler condones so my peers nor i have done it before
Old 02-21-2014, 03:31 PM
link040188's Avatar
link040188
the head was redesigned for 2010 so the 2003-2009 head is not the same as 2010 up
Quick Reply: hemi head compatibility
