Transmission help please
Old 01-23-2014, 08:03 PM
Cmckinney99's Avatar
Cmckinney99
Cmckinney99 is offline
Default Transmission help please
I dont know what trans my 1985 d150 shortbed has in it i dont know if its a 727 or a a904 do any of you guys know how to find out
Old 01-23-2014, 11:01 PM
xjarhead69's Avatar
xjarhead69
xjarhead69 is offline
Old 01-23-2014, 11:11 PM
moe7404's Avatar
moe7404
moe7404 is offline
most likely a 727. dodge tened to use 727 on trucks. the shape is the give away. find a site that that has pics.. trans-go should have one. a shift kit from them is easy to put in, but do not make it to hard of a shift. if your rear end is a 7 1/4 a shift real hard WILL strip the spiders over time. i found an EXTERNAL trans filter. i have one in hopes i wont to change the internal filter as much. point of history the 1963-1964 new yorkers had one from the factory. use high pressure hose. NOT carb fuel line. chrysler trans should be using 3/8 tubing.
man o man i about forgot yes its a cut & past sorry. __________________
after you clean the trans. add this to your*chrysler*trans. an external fluid filter
1. go to auto-zone. get 2210, its called a power steering filter, but it is for transs to. it is for 3/8 tubing. by (magna-fine) be sure to use high pressure hose. Reff:http://www.magnafilter.com
2. for other sizes wix 58964 5/16 tube size
Old 01-24-2014, 04:21 PM
Cmckinney99
Im trying to get gelp becauee my torque converter is bad
Old 01-24-2014, 05:10 PM
Cmckinney99
Do you guys know how to put pictures on here im using a cell phone
Quick Reply: Transmission help please
