Changed gears... Now ABS light on
Old 01-23-2014, 07:17 PM
Canuck26's Avatar
Canuck26
Canuck26 is offline
Default Changed gears... Now ABS light on
So I changed from 3:55 to 4:56 gears with a posi... The ABS light is on and engages like it should as if you were sliding under normal braking conditions. Does anyone know the cure for this?
Old 01-23-2014, 11:46 PM
weedahoe's Avatar
weedahoe
weedahoe is offline
Hall of Fame Member
Service manual says you are supposed to remove the sensor on top of the diff housing BEFORE pulling out the diff. I would replace the sensor
Old 01-24-2014, 03:20 AM
abarmby's Avatar
abarmby
abarmby is offline
Did you make sure the "tone ring" was reinstalled back onto the ring gear?
It's been missed out before.
Al.
Old 01-28-2014, 11:14 AM
Canuck26's Avatar
Canuck26
Canuck26 is offline
Hey guys thanks for the input. Been too damn cold to try much. But I replaced the sensor. Abs light is still on. I believe the abs was actually engaging cause of the speed sensor on hub. Cleaned it up and it's all good. Still blinking abs light though.
Quick Reply: Changed gears... Now ABS light on
