Power Steering Gearbox Replacement
Old 01-22-2014, 02:55 PM
Packy37's Avatar
Packy37
Packy37 is offline
Default Power Steering Gearbox Replacement
I got a 1996 Dodge Ram 2500 v10 and the power steering fluid is leaking out by the gear where the pitman arm bolts in. I am just gunna replace the whole power steering gearbox. I'm just curious if anyone knows all the tools that I will need. I know you can rent a pitman arm remover from Autozone. If anyone knows exactly what tools and what size sockets I'll need that would be great!
Old 01-22-2014, 04:45 PM
Matt Nickerson's Avatar
Matt Nickerson
Matt Nickerson is offline
What kind of replacement box did you get/have in mind? If you're thinking an oem rebuilt one from the auto parts store, don't even bother. They don't last. Better off replacing the seals and bearings yourself for like $30.
Spend the extra $ on a redhead or borgeson box..or just deal with the leak like I've done.
To replace it, you need an allen bit/hex key for the steering column coupler bolt. A socket for the 3 frame rail mounting bolts. And a wrench for the power steering lines, pretty sure you need to use a crow foot type wrench not a regular open end. And of course you need the pitman arm remover and an impact wrench.
Old 01-22-2014, 05:20 PM
AtomicDog's Avatar
AtomicDog
AtomicDog is online now
That leak is pretty easy to fix - you can purchase a lower seal kit from places like NAPA for about $20. To keep it from leaking again, you must be sure to adjust the slop/movement in the steering box output shaft by loosening the lock nut on top of the steering gear box and tightening the allen head bolt just enough to remove the slop/movement of the steering box output shaft, then re-tighten the locknut. This will ensure that the seal will live and not leak.
If your steering box is all around sloppy and your truck isn't handling well, by all means replace it. Redhead and Borgeson are the best replacement options available. I replaced mine with a Borgeson unit a few years ago and I've been pleased with it.
Old 01-22-2014, 06:43 PM
Packy37's Avatar
Packy37
Packy37 is offline
Well ever since I got the truck which was almost 4 years ago there is a lot of play in the steering. You can turn the wheel quite a bit before the wheels turn. Doesn't the gearbox control that? So if I replace it shouldn't it tighted that up and reduce the amount of play? If I just replace that bottom seal do I even have to pop the gearbox off?
Old 01-22-2014, 07:16 PM
AtomicDog's Avatar
AtomicDog
When you have a moment, please update your profile to include details about your truck.
The seal can be replaced with the steering box in-place. All that needs to be done is to remove the large nut (1-5/16", I believe) that holds the pitman arm in place, remove the pitman arm with a puller, then remove the snap ring that holds the washer and seal in place.
Movement in the steering can be caused by several things. The steering box, the steering column, loose joints in the intermediate shaft, wheel bearings, slop in the inner and outer tie rods ends are some of the most common causes. When I bought my truck used (which had about 125,000 miles), I ended up rebuilding the entire front end to restore decent driveability.
Old 01-22-2014, 08:38 PM
Packy37's Avatar
Packy37
Packy37 is offline
It has play but it's not like it's a massive amount of play where it is unsafe to drive. My grandpa said usually it's a bad idea to replace just that seal where the pitman arm goes into. It's a 96 with a lot of original parts so I'll probably just replace the whole gearbox. Plus I'll know it'll be safe.
Old 01-22-2014, 08:43 PM
AtomicDog's Avatar
AtomicDog
Replacing the seal does nothing to compromise the safety of the gearbox and my truck is also a 1996 3/4 ton truck (same as yours). After I replaced the seal and adjusting the gearbox, it never leaked again. I drove it for another 6 months to a year and noticed that I had too much play in my gearbox (after replacing all of my other front end parts during my front end rebuild) and it was time to replace the steering gearbox.
Old 01-22-2014, 09:20 PM
The adjuster, and jam nut he was talking about will remove a lot of the play in the box. (but, not all of it...) I have done a couple of these. Usually works fairly well. If they start leaking again though, I just replace the whole box.
Matt is correct though. If you just buy a 'stock replacement' from the parts store, you are going to be right back in the same situation again within a year. If you replace the box, get the redhead, or borgeson box. Then, never worry about it again.
Old 01-22-2014, 10:03 PM
Packy37's Avatar
Packy37
Packy37 is offline
Money is kind of tight for me right now. Around August is when I'll have a lot more spending money lol. I'm just gunna replace the gearbox with one from Autozone just to get me by. How much are them better gearboxes that you guys are talking about?
Old 01-22-2014, 10:32 PM
Ram Driver's Avatar
Ram Driver
Ram Driver is offline
I have a 2000 Dodge Ram with a 167000 miles on it, and the steering box is also very loose. I can turn the steering wheel more than a quarter of a turn going down the road before the truck turns. I took the truck to a shop and had the suspension and steering inspected, had a few things replaced that helped a lot, but the steering box on my truck is shot. I will be getting a redhead steering box in the next couple of months.
The redhead steering box is $329.00 dollars with exchange. there are other steering boxes you can get that are cheaper, about half the price, but the redhead steering box is the best one you can get in my opinion.
Quick Reply: Power Steering Gearbox Replacement
