3rd Gen Durango 2011+ models
2012 Durango Crew Towing Capacity
Old 01-19-2014, 05:29 PM
mlsa3's Avatar
mlsa3
mlsa3 is offline
Default 2012 Durango Crew Towing Capacity
I have a 2012 dodge Durango crew with the 3.6 Pentastar engine...it does not have the tow package.
Can anyone tell me what my towing capacity is...I added a hitch and I pull my bass boat but was wondering what the towing limits are without the towing package.
Thanks
David
Old 01-19-2014, 05:38 PM
mcfarl58's Avatar
mcfarl58
mcfarl58 is offline
Default nm
nm, ok
Old 01-19-2014, 05:46 PM
Wash Man's Avatar
Wash Man
Wash Man is offline
Should be the same since the aftermarket hitches bolt to the same points in the frame that the factory one does. If hauling long distances however, I would check with the dealer to see if a transmission cooler is part of the tow package for your year model vehicle.
Old 01-19-2014, 06:26 PM
Pdwelch2000's Avatar
Pdwelch2000
Pdwelch2000 is offline
It will be less than the 6200 since you lack the transmission cooler and suspension. Someone will chime in with the math. 3500 or less seems reasonable.
Old 01-19-2014, 08:50 PM
Crew Member's Avatar
Crew Member
Crew Member is offline
Don't assume. I don't have the tow package but the tranny is still cooled.
And re the suspension, if the rear sags too much without it you can just move the weight back on the trailer to reduce tongue weight.
Old 01-19-2014, 08:52 PM
Crew Member
Originally Posted by mcfarl58
Probably the total capacity with the tow group, divided by 2. So, about 3100 lbs.
Reason i say that is because a class iv hitch on the tow group allocates the weight over both axles. Because you only added a hitch afterwards, you are putting it all on one axle (rear). Look up the gross axle weight. That should tell you.
Ummmmm..... What?
This is insane.
Old 01-19-2014, 09:31 PM
mcfarl58's Avatar
mcfarl58
mcfarl58 is offline
Tow group has heavy duty engine and transmission cooling. Also has load leveling suspension. V6 needs this. The v8 hemi has all these without the tow group. Moving weight to the back is extremely dangerous as it leads to swaying.
Old 01-19-2014, 11:52 PM
zaktrafton's Avatar
zaktrafton
zaktrafton is offline
What what in the what?
Old 01-20-2014, 09:37 PM
wi-steve's Avatar
wi-steve
wi-steve is offline
Default load leveling?
YOu guys have me curious. I have a 2012 with to package. Is there an easy way to identify if it has load leveling?
Old 01-21-2014, 12:37 AM
clh1220's Avatar
clh1220
clh1220 is offline
The manual has a note in there that's says without tow package it's 3500.the tow package does come with the load leveling shocks .
Quick Reply: 2012 Durango Crew Towing Capacity
