Where to put flush T on 97 Ram
Old 01-19-2014, 04:13 PM
2000 Neon's Avatar
2000 Neon
2000 Neon is offline
Default Where to put flush T on 97 Ram
Ok so I have the dreaded no or minimal heat in my new to me ram. It had a heater core done recently and has been like this at least since then according to the previous owner.
I read about putting a flush kit T in the heater hose near the core to help release the air. Which side do I put it in drivers or passenger?
Which side is inlet, which is outlet?
Thanks for any help, hoping to solve this asap as its a bit chilly in there now.
Old 01-19-2014, 04:56 PM
Those on passenger side is inlet, hose on drivers side is outlet. You want to put the T in the outlet hose, at its highest point. Unfortunately, that is RIGHT by the heater core. (fun place to work in.....) I just lay across the top of the engine. If the engine is warm, keeps me warm too.
Old 01-19-2014, 05:20 PM
2000 Neon's Avatar
2000 Neon
Ok thank you. Do you think doing it withough draining the system will work?
Old 01-19-2014, 05:23 PM
Certainly. You may lose a little bit when you cut the hose, just don't let the free end flop down to low, or it will suck out a bunch.
Old 01-19-2014, 08:01 PM
2000 Neon's Avatar
2000 Neon
Well put the T in, been burping it for a couple hours. It's gradually getting better but still not great. Are these cores really this much of a pain to bleed?
Old 01-19-2014, 08:05 PM
All you should really need to do for the heater core is just start the engine, crack open the T, when you get just coolant flowing, and no more air bubbles, tighten it back up. Once the engine warms, you should have good heat, if you don't, something else is going on.
Old 01-20-2014, 10:45 AM
Annihilator_X9's Avatar
Annihilator_X9
Annihilator_X9 is offline
What size Flush T did you get? I'm going to do this as well.
Old 01-20-2014, 10:46 AM
I don't think you can get them individually, they come in a kit. It will have a couple different sizes.... use the one that fits.
Old 01-20-2014, 11:22 AM
2000 Neon's Avatar
2000 Neon
I bought mine individually from a local parts store. Cost me $2.00 + two clamps. Its a 5/8" T.
I put it on the drivers side beside the brake booster. Was a little distance away from the core outlet but where it is I can lift up the hose and hang it with a piece of wire so its higher than the rest of the system including the heater core while I am bleeding the air out.
Not sure if its the best way but so far it seems to be helping.
Old 01-20-2014, 12:58 PM
Annihilator_X9
Thanks for the info guys!
Quick Reply: Where to put flush T on 97 Ram
