[3rd Gen : 96-00]: Trans-Code- PO733
Old 12-18-2013, 05:14 PM
plum's Avatar
plum
plum is offline
Unhappy Trans-Code- PO733
I have 2000 dodge caravan the Codes come up PO700 which means transmission problems then the second code is PO733 gear 3 incorrect ratio that is fine. But what does it mean & how do you fix it? What is the diagnostic tree for PO733? NEED HELP, THANKS: I changed the transmission solenoid pack, input,output speed sensors,filter oil ATF+4 but it is still in limp mode. Help
I have taken the cable off the battery to clear the codes & engine light then I put the scanner on and PO733 has come up about 3,4, times every time. THANKS:
Old 12-19-2013, 12:34 AM
master tech's Avatar
master tech
master tech is offline
Site Moderator & Tech
Now if you drive the van, Does it shift from 1st to 2nd and then into limp in? If it does, Then the transmission may have a broken hub with shaft. That means the problem is inside the transmission.
Old 12-19-2013, 02:29 AM
Cougar41's Avatar
Cougar41
Cougar41 is offline
Can be caused by slipping clutches. Have the CVI numbers checked to verify.
Old 12-20-2013, 10:22 PM
master tech
That's very true. A clutch test would also verify if 3rd gear is slipping. Because slipping or broken hub, will have a RPM reading when it should be at zero.
Quick Reply: [3rd Gen : 96-00]: Trans-Code- PO733
