does front diff. need limited slip additive?
Old 12-13-2013, 10:38 AM
ljinnc's Avatar
ljinnc
ljinnc is offline
Default does front diff. need limited slip additive?
Hi, I recently changed the rear differential fluid in my 98 Dakota 4x4 and put limited slip additive in it, my question is does the front axle require the additive?
Old 12-13-2013, 10:57 AM
sxrsil3nt's Avatar
sxrsil3nt
sxrsil3nt is offline
No the front is not an LSD differential.
Only the rear.
Old 12-13-2013, 08:16 PM
atthewmartin114's Avatar
atthewmartin114
atthewmartin114 is offline
ill be honest with you i dont add any thing to eather front or rear on my 97. and i have a limited slip. i think its personal pref honestly because our front diff matcher the chevys and they dont use additives and either does any other limited slip rear end
Old 12-13-2013, 08:45 PM
Tom A's Avatar
Tom A
Tom A is offline
Section Moderator
Chevy limited-slip diffs use an additive, as does any clutch-type limited-slip I'm aware of. Don't be surprised if you find your clutches in little pieces one day.
Old 12-14-2013, 01:59 PM
TheNewbie's Avatar
TheNewbie
TheNewbie is offline
+1. ANY LSD should have the additive. It does not vary from manufacturer to manufacturer.
Quick Reply: does front diff. need limited slip additive?
