backfire loss of power
Old 12-13-2013, 10:06 AM
michaelgeller294's Avatar
michaelgeller294
michaelgeller294 is offline
Default backfire loss of power
i have the 5.2 i have checked the o2 sensors nothing wrong with them checked the map sensor the plenum seems to be fine changed the plugs and wires the cat was gutted after this happened it wasnt the issue im running out of ideas as to what it can be it throws about 20 codes when i plug it in but there never the same codes
Old 12-13-2013, 11:10 AM
TheBigRedTruck's Avatar
TheBigRedTruck
TheBigRedTruck is offline
need info on your truck...year model etc..
Old 12-13-2013, 11:17 AM
michaelgeller294
its a 99 dodge ram 1500
Old 12-13-2013, 11:39 AM
Ham Bone's Avatar
Ham Bone
Ham Bone is offline
Sounds like your PCM is going bonkers. Did you disconnect battery when changing stuff? Even if you did, disconnect battery then cut your headlights on to drain the system. Then reconnect and see what happens.
If it's still going crazy it's time to start to tracing grounds
Old 12-13-2013, 11:41 AM
michaelgeller294
the battery was out of it for a month and its still acting up
Old 12-13-2013, 12:17 PM
Time for a compression/leakdown test.
Old 12-13-2013, 09:01 PM
ReadRam's Avatar
ReadRam
ReadRam is offline
I'm lost. Besides throwing codes, what is acting up?
Old 12-14-2013, 05:09 AM
michaelgeller294
it backfires when at idle and has a major loss of power it takes a full mile to hit 60
Old 12-14-2013, 10:55 AM
Backfiring out the exhaust, or intake?
Old 12-14-2013, 10:58 AM
dhvaughan's Avatar
dhvaughan
dhvaughan is offline
do a compression test.
Quick Reply: backfire loss of power
