08 3.7 Headproblems? waterpump?
Old 12-11-2013, 10:14 PM
08RecordRam's Avatar
08RecordRam
08RecordRam is offline
Default 08 3.7 Headproblems? waterpump?
So I got an 08 ram with 280k miles
Never had too many problems with it waterpump, wheel hubs, fuel pump
ANd the other parts from when it was stolen, hit a cow, deer, pigs, signs, trees and you name it whatever else.
So My truck has been overheating the last few days.
Poped the hood noticed fluid was low but full in rad looked around.
Thermostat house bolt was missing got a new one and changed thermostat.
I put new thermostat in just how the old one came out with the hole up top also.
As far as the waterpump I changed it last summer but Iam not sure if its working Since both the lower and upper rad hoses feel cold, but there are 2 3/8 hoses above the rad hose that goes to the thermostat that are hot to the touch.
When the truck gets to the running temp which takes about 10 mins. The oil light blinks when i take off from a stop and the engine sounds like a diesel when i take off. Iam not sure if its bc I didnt change the oil for 19K miles or what. But I did changed it before this started happening. Ive check it again and its doesnt give a milky apperance or anything.
The exhuast it puts out a mild steam that dissapers after it gets to the back of the truck. Drips enough I could fill up a cup in a few minutes.
(Ive got 2 6 inch tips dumped under the truck right behind the cab)
I cant notice a smell bc of my profession on the oil rigs and iam a heavy smoker.
Nor can I tell if its normal bc I havent had exhuast for 2 years I barley got true duals last week after getting my 7th inspection ticket and threatened to have my truck impounded by a judge!
The heater in my truck also stopped working a about 20 miles ago 30 miles total since it started overheating.
Can any of you nice folks in ram land suggest where I should go from here how to tell if its my waterpump, or something in my engine?
Also Ive probley had 3 different types of collents in my truck in the last 6k miles 2 different oil places universal, green I put in and about 1/3 of a gallon of red, and the yellow I put in it half gallon when i changed the thermostat.
I think I could fix it if its the engine but I dunno if the price of rebuilding the engine would be the same as getting a crate motor or something from craigslist and just using all my parts I got now, for the same price.
IVe never torn into an engine but I am a master plumber and have a high mechanicaly apatitude But I couldent tell you what a cam or a head or valve or any of that otherstuff is.
Again any help is apperciated! And I hope if anyone is above the 200K+ they have enjoyed there truck as much as mine.
Edit I just want to say sorry about my spelling and grammer I grew up in Hicktown texas sO I hope its not annoying for all of you! Please bare with me!
Old 12-12-2013, 12:36 AM
Adambomber's Avatar
Adambomber
Adambomber is offline
Idk if the 08 is different than an 03, but does your have the coolant resevoir with the pressurized cap? Is so, take of the cap and start your truck. If there is not a stream spraying into the coolant resevoir, then your waterpump is bad. Does it make a noise that sounds like its coming from a pulley if you open the hood?
Old 12-12-2013, 10:16 AM
chuck_hammer's Avatar
chuck_hammer
chuck_hammer is offline
I have seen the impeller on the water pump break off. and not move the water...but on the outside of the pump look fine.
remove the water pump... and check that the NEW thermostat is not stuck closed.
and I hope my V6 runs that long.
Old 12-12-2013, 12:57 PM
08RecordRam
i tried the suggestion u gave me and the waterpump seems to be working...
Guess the combustion test in teh rad is the only thing left to do thenm most likely ill be dropping a good amount of breaed on the parts.
I figure ill go ahead and change the chain and sprockets for the timing while iam in there YAY
Old 12-12-2013, 12:58 PM
08RecordRam
I think i will go ahead and break out the waterpump and get a new one, since the one I installed still is under warranty.
I think that will do just to be safe before i tear up the engine.
Thanks guys for the replys so far anything anyone suggest I will take to heart!
Old 12-12-2013, 02:41 PM
Prismatic's Avatar
Prismatic
Prismatic is online now
You let it go 19k miles without an oil change? The 3.7 is basically a 4.7 with two cylinders shaved off. These engines already have a sludge problem if you don't maintain the oil. You probably either clogged some oil passages, the screen, or both. Run an engine flush through... maybe a few times. Then put some seafoam in the oil and run it for a few hundred miles, then change with full synthetic and a quality filter.
Old 12-12-2013, 04:09 PM
08RecordRam
Sadly i did let it go that long, partly bc of ignorence. I was thinking I changed the oil but i guess I didnt.
How would i go about flushing the engine?
Old 12-12-2013, 06:53 PM
Adambomber's Avatar
Adambomber
Yeah, like chuck hammer said, the water pump impeller can break and there is no outside sign. This happened on my 2003 dodge ram. I advise to take off the waterpump and check the impeller, it could have cracked around the center bolt and under a heavy load spin on the shaft and not turn the water. This was the case on mine but I didn't catch it until it completely stopped working. Also I agree that in the 3.7 and 4.7 you HAve to change the oil every 2000 miles
Old 12-12-2013, 07:09 PM
08RecordRam
I appreciate everyones replys and advice I will be tackeling this tommorrow or saturday. Ive been cutting trees at my house and the neighbors after the bad storms and cleaning up.
One question I do have is IF i am leaking coolent IF it is going threw the exhuast the only cause for that would be the heads right?
Iam really hoping for the waterpump even at 280k miles i really dont want to have to tear up the motor and basicaly rebuild it. I could go to get a new truck but my uncle and grandmal are really giving me a hard time about buying one since i just bought 43 acres.
Old 12-13-2013, 02:45 AM
KasperR34's Avatar
KasperR34
KasperR34 is offline
sell it and buy a hemi
Quick Reply: 08 3.7 Headproblems? waterpump?
