2005 dodge 4.7 manifold
I need some help with a '05 4.7 intake manifold
Hey guys, I've bought a 05 4.7 manifold but there is a 1-1.5" hole on the right side (from our view, left from the engine's), about 6" behind the TB. It looks as if a big hose or cap should have been there, but there is just a hole. Can any of yall show me a photo of what your manifold looks like and what goes there and any way I could plug it? It would be greatly appreciated.
Thank you,
Duncan
Thank you,
Duncan
Thank you,
Duncan
Thank you,
Duncan
That is for the EGR Valve. ON the 05-11 there is a Copper tube with an insulating bung that would typically fill that hole. Depending on how the EGR valve is routed on your 01' it may or may not use that hole. If your engine is using another method, that hole may simply be plugged with an appropriate Piece of fitting. However should you decide to plug that hole, be sure that it is secure because if it leaks your Idle air control circuit will s*** bricks..
