6.4 cam swap
Old 11-16-2013, 11:07 PM
hemi5.7express's Avatar
hemi5.7express
hemi5.7express is offline
Default 6.4 cam swap
I'm looking for info on swapping a 6.4 cam into my 2011 5.7 powered 1500 with a 3.55 gear . if it can be done, can it be done with factory lifters, pushrods, rockers, springs, and tune an not cause an issue with overall reliability an performance? And how much of a performance increase can I expect? Any info is appreciated, thanks
Old 11-17-2013, 02:02 AM
jasonw's Avatar
jasonw
jasonw is offline
Site Moderator
Welcome to Dodge Forum. Will move you to the correct spot.
For future reference:
https://dodgeforum.com/forum/dodge-r...ead-first.html
Old 11-17-2013, 09:05 AM
LU229's Avatar
LU229
LU229 is offline
I wont say that it can or can not be done, but my question to you is... why.
Not seeing the point to replacing one OEM cam for another... i dont see the gain from it.
Old 11-17-2013, 01:57 PM
LVRR's Avatar
LVRR
LVRR is offline
You would probably get a lot more performance switching your 3.55 gears for 3.92 or 4.11's. I think this would be much easier and less time consuming. Unless you know how to set up cam phasers or someone who does you can run into problems
Years ago when I was into this stuff we would always replace the lifters and springs with a new cam along with any races or bearings, so being old school I would replace all these items. Setting up the old cams for proper timing was easier than the new ones today.
Quick Reply: 6.4 cam swap
